Finally finished gauges :D
Well, a while back i asked in another topic about tach swaps and luckily everything went well with my tach swap. Im just going to give out a small talk about how i did mines
![]() Here is the pic of the back. ![]() As you can see, I cut a hole in the back very carefully with a kitchen bread knife, lol. Took a while but got the job done. You can also see the black tape where i welded the fuel pump connectors to route the wires to the lower bottom quadrant at the left. ![]() Just got some nuts to connect wires with fuel gauge and kaboom. DONE! ![]() ![]() I decide to paint the black cover entirely white from inside and out.(The lights are a lot brighter with some blue LED's i installed.) |
3/4 Ton Rodder
Re: Finally finished gauges :D
I'd like to see pics of that installed. It looks great!!!
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
In the Forgotten far North.
![]() Join Date: Jul 2007
It does look nice! I like the white cover too. Even if you don't see it when the gauge bezel is installed over it, just knowing it's there is satisfaction enough (Mine's Bahama Blue on the outside & white on the inside)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
LOOKS GOOD!!!
does your tach work? unfortunately my tach doesn't work. I found a place online that will fix it for $165 tachman.com just FYI ![]() I did the same white paint treatment gives it a cool halo effect http://67-72chevytrucks.com/vboard/s...&postcount=217
![]() ![]() Last edited by joe231; 12-21-2009 at 12:09 AM. |
