Old 12-21-2009, 12:10 AM   #1
'70GMCStep
Breaking in problems, or did I do something wrong?
Installed CCP; tubular lower and upper control arms kit, then upgraded the front brakes to disc brake kit. Not sure why I am noticing a 1/4 inch drop on left front. Had it gone over by mechanic friend, and aligned. Drives and brakes straight. Steering has been great since I bought it. Where do I go from here?
700 R4 I put in pulls strong, but does that lugging thing around 40-45 or so. Before that and after that point, nothing odd. Normal or was the tranny switch set correctly, tv cable?
Just got it on the road a few days ago and DONT want to mess it up. Wife would kill.
I appreciate it.
'70GMCStep
'70 GMC Shortbed Stepside
'65 Chevy C-10
'70GMCStep is offline   Reply With Quote
Old 12-21-2009, 12:14 AM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Breaking in problems, or did I do something wrong?
Man sorry I couldn't be any help, but tell your wife not to kill Mr. T.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-21-2009, 12:26 AM   #3
62gmc910
62gmc910's Avatar
Do you have a vacuum switch on the lock up ,try touching the brake pedal to disingage the lock up to see if the lug dissapears
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-21-2009, 08:19 AM   #4
lakeroadster
I pitty da fool who messes with Mr. T! circa 1978
As for the 1/4" drop drive it for a while things tend to settle. If it is still a problem in a month or so how about adding a 1/4" shim.
Can't offer any advice for the 700 R4... I am a Muncie kinda guy.
lakeroadster is offline   Reply With Quote
Old 12-21-2009, 08:59 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Sometimes its the rear that will cause the front to be off a little. I would definitely let it settle for awhile and see how it goes....if not you can try swapping coils side to side to see what happens. Little bit of time but no $$$$
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-21-2009, 10:15 PM   #6
jbon64
jbon64's Avatar
maybe wire in a switch for your converter lockup . that way it will only lock up when you want it to. i have a 200r4 (similar OD trans) and it did the same thing until i wired in a toggle switch to activate the lock up . now i only use the lockup if i'm at highway speeds
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 12-22-2009, 01:09 AM   #7
'70GMCStep
Liking the toggle switch to activate plan. Think I'm going to slip in a tranny temp gauge while I'm at it from what I hear about 700 r4's, if nothing else, some more peace of mind. Going to let the beast roam around and see if the suspension takes it's place. I appreciate the help!
That was just a little humor about my wife earlier on my part. She comes from a gear head family and helps in the garage. Good lookin' and knows a way around a garage...priceless...
'70GMCStep
'70 GMC Stepside SWB
'65 Chevy C-10 LWB
Old 12-23-2009, 10:48 PM   #8
ampsyco
lugging is usually normal for overdrive trannys at the point of lockup.
under light or partial load i would say its normal.
ampsyco is offline   Reply With Quote
