cab mounts
bought new cab mounts old ones rotted . there are two 1" and two 1 1/8" which one is front and which one is rear . did not come with instructions. thanks for any help.
Don't blame the messenger
Re: cab mounts
Take all look at this thread, it might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=192342
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." |
Re: cab mounts
LMC catalog is great for it's illustrations as well..
i'm guessing taller in the back.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: cab mounts
Thanks for the heads up on doing this process.
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
Re: cab mounts
thank for all the help i did see that thead was some help but dont show which is front or back.. they sent washers that dont fit the bolts but i have a drill. thank to my air chisel bolt came out easy .
Re: cab mounts
Got to ask this;
Do any of you know what kind of bolts, nuts and washers are needed for 3/4 ton. My new set did not come with hardware and I am not seeing any identification in any of the books for what type and size all of the hardware needs to be. I thought about using the old ones to compare, but I don't know how well they will come off when that time comes. Thanks all. R/
Re: cab mounts
can some one tell me thje lenghts and size of the cab bolts and does the larger bushing go to the rear?
#8 | |
Re: cab mounts
GROVE STREET CUSTOMS est. 2005 ![]() 67' C10 LWB/350/T400 69' C10 SWB/454/T400 71' C10 LWB/383/ 72' C10 SWB/350/T350 15' Crew Silverado/6.2 |
Re: cab mounts
there is nothing mentioned about length or size of bolt
Re: cab mounts
good post. I'm thinkin about doin mine and this is a nice heads up!!!
Re: cab mounts
someone told me the bigger bushing goes to the rear thats what i did . i also sprayed my bolts with pb blast they come right off had to use my air chisel to remove bolt out of the floor go slow so you dont tear the floor up.my bushings came with new bolts and nuts with washers. if i go out today i will try to remember to see what size and how long.
Keep On Keepin' On
Re: cab mounts
Good info..
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
#13 |
Re: cab mounts
that would be greatly appreciated mine only came bushings and washers from performance online
#14 |
Has more rust than truck...
Re: cab mounts
Front 9/16x6"
Rear 3/8x5.5" |
#15 |
Re: cab mounts
your to kind thank you
#16 |
Re: cab mounts
Your the man. Thanks for posting this.
R/
