Help fixing a bead leak
I just put new tires on a set of used aluminum rims. Three of the tires are fine, but one leaks around the bead. It loses about 5 psi a day.
Is there a way to seal this up? Can you break the tire down and put permatex or some kind of sealer on the bead? I don't think I can (or want) to put a tube in it, because of the valvestem. I should mention it's on a daily driver (not a drag car). Any suggestions? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-21-2009 at 02:01 PM. |
1962 C-10
Re: Help fixing a bead leak
I would take the tire back off the rim and clean the rim real good with sandpaper or emry cloth.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Any tire supply shop will have bead sealer that works great to stop leaks.
Down......with the sickness!! |
18 Till I Die
Tire off and wire brush all the crustys, then yea sandpaper or emery should do it.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
On a budget like Fred Sanford
Agree with all above. They should have some clear/yellow colored gel (can't remember what it's called) to put on the bead to help seal it after the rim is completely cleaned.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 12-21-2009 at 04:11 PM. |
Project Optimus Prime
Thats good 2 kno
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
are you sure its the rim and not a tear in the tire bead?
We have a new tire shop here in Indiana Discount Tire that would probably fix it for free. if you do not have a place like this any tire place should fix it for under $10
