Old 12-21-2009, 02:35 PM   #1
jlolson
jlolson's Avatar
Drive Shaft Question
'71 C20 LWB
When I removed my drive shaft to replace the carrier bearing assembly I found 2 spacers between the frame mount and the U-shaped bearing assembly. Total spacing was about 3/4-inch. They are clearly home-made shims and when installed they would move the drive shaft down.
Any idea why those spacers would be there?
Should I put them back in?
Thanks in advance.
jlolson is offline   Reply With Quote
Old 12-21-2009, 11:44 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
Re: Drive Shaft Question
the only reason to use spacers is to get the drive line angles flatter. when i put in the gear vendoe overdrive i hae to do several mods to my drive line and relocate the carrier bearing back 12 inches..anyway i ended up putting a spacer under the trany to get rid of some angles in the ujoints.
id say look and see what way makes the driveline the flattest and go with that.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
