12-21-2009, 04:22 PM | #1 |
The Beach Cruiser
Front end alignment after new parts
I am planning on replacing the following on my 66 panel
• Upper and Lower Ball Joints • Outer and Inner Tie Rod Ends • Adjusting Sleeves • Idler Arm Pitman arm My question is how do I line everthing up close enough to drive it to the alignment shop? Are there any diagrams around? I would take it to a shop and have them do it all but I want to paint all the parts berfore the install. Thanks for any help.
1999 Silverado DD 1966 Panel Truck 2003 Harley Road Glide 1967 Schwinn Tandem Single Speed |
12-21-2009, 04:55 PM | #2 |
It'd be alot cooler if you did
Re: Front end alignment after new parts
I just make the tie rods the same length as the old ones and make sure you go driectly to the alignment shop.
