Visor problems
This is probably a very simple fix, but wanted to run it by you guys before I attack it.
My interior drivers side covered visor is falling down on me when i drive. The problem is at night, the thing doesnt want to stay up and i would rather it go up or down on demand rather than always down. Is there a screw I turn to tighten it, or is this something i will need to replace all together? Its a standard visor, appears to be the original or an original repro. Thanks
'51 Chevrolet 3100 |
Re: Visor problems
No help here, all mine had when I bought it was the rod, I sewed up a piece of old levi's like a curtian with some 1/8" masonite inside and let it flap. I'm short so it doesn't hit me in the forehead.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 12-21-2009 at 07:32 PM. |
Re: Visor problems
Try slightly bending the rod to put some friction on the visor.
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
Registered Chevy Owner
Re: Visor problems
Thats would I would do. I don't think there is really anything that holds it on to the shaft. It's just friction.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
Re: Visor problems
I looked at one I have with a visor. The masonite is attacked to a round spring steel bracket that slides over the rod. The circle doe not close, so you can compress it to get more friction to hold the visor in place.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: Visor problems
These are good ideas... also, rather than bending the rod, could i put the female end of the visor into a bench vice and wouldnt that make the fit tighter as well?
I guess i can always bend back the male end, but i cant bend back the female part. Or do i risk ruining the black exterior material of the visor? Thanks
'51 Chevrolet 3100 Last edited by chevyky; 12-22-2009 at 01:25 PM. |
Re: Visor problems
I would think protecting it with a towel and using oak to clamp it would protect the material. Vice grips might be enough.
Re: Visor problems
Just get an outside visor and you can throw those inside ones away for good!
Re: Visor problems
Oh i plan on it... thats the long term plan at least. In the meantime i think ill just bend the rod.
