12-21-2009, 06:15 PM | #1 |
Surface rust treatment?
I've just sanded down a Texas 68 stepside that had a lot of surface rust. How do I treat the metal to stop the rust from popping up again?
Do I put this under the primer? Under the body putty? I will have to do some minimal putty work to make the panels absolutely flat. |
12-21-2009, 06:24 PM | #2 |
Redefining LowBudget
Re: Surface rust treatment?
welcome to the board
I would use an epoxy primer...dp 60..dupont its hard as a rock wears like iron and I would use it even under and thin body work |
12-21-2009, 06:32 PM | #3 |
Farmtruck desciple
12-21-2009, 06:43 PM | #4 |
OSPHO, brush it on bare metal, then lightly sand before primer.
12-21-2009, 06:50 PM | #5 |
low n' slo
if theres no rust craters just spray epoxy primer on it. when i sanded my hood down, i sprayed some rust converter over it, then sprayed epoxy primer over it. can never be too sure about rust...
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-21-2009, 07:58 PM | #6 |
member #16
Welcome to the board. There are alot of products that work well. I have used rust-mort with good results before the epoxy primer
. http://www.tcpglobal.com/autobodydepot/rustremove.aspx
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
