12-21-2009, 06:49 PM | #1 |
slow drain on the battery
so far i have used a volt meter between negative battery post and negative battery cable, and even with everything unplugged from the fuse box there is still current between the two. is there any other systems that dont go through the fuse box? or any other ideals?
12-21-2009, 08:32 PM | #2 | |
Re: slow drain on the battery
12-21-2009, 08:35 PM | #3 |
Connecting a voltmeter between a battery cable and post won't give you meaningful info. You want to connect an ammeter or test light that way.
12-21-2009, 08:45 PM | #5 |
Robert Olson Transport
or do you have a memory radio with electronic presets/ clock?
12-22-2009, 12:46 AM | #6 |
ive dont have a clock except on the radio and i unhooked that before doin anything and ive tried the test light with the same results
12-22-2009, 11:47 AM | #7 |
dang its hot
pull the dome bulb in the ceiling out and recheck...I had a door switch fail and dimly lit the dome bulb...granted, I don't drive mine for a week at a time but battery would be dead
12-22-2009, 03:49 PM | #8 |
ill try that it does take atleast a week or more for it to drain the battery all the way
12-22-2009, 05:39 PM | #9 |
78K & 79C Jimmys
try taking out a fuse at a time.....and wait
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
