Old 12-21-2009, 10:39 PM   #1
BMSJaX
BMSJaX's Avatar
Oil filter mount question
Alright I have a 350 casting 3970010 71-77 made in '74(ran the numbers) and I noticed something odd with the filter mount. 71+ blocks were all spin-on filters right? So they should have a mount that looks like pic one right? Even my '69 307 uses this. But mine has pic two which is a adapter for canister to spin-on? It started leaking around the top so I was just gonna replace it, not knowing its condition, but now I do not know which to get... any ideas? If it doesnt need the adapter I dont want to just replace it with a possible incorrectly used part.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 12-21-2009, 10:44 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Oil filter mount question
Are the parts interchangeable??? Somone here did this not too long ago and I cant remember who it was. I'm sure someone would know in the engine section. My experience with a '71 400 had the spin on bracket that you show. My '69 also had a spin on.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-21-2009, 11:00 PM   #3
62gmc910
62gmc910's Avatar
the top pic is the normal spin on like you said , the lower one mounts on top of the old style cartridge bypass block , you should be able to put the top style mount on your 010 block , I normally block the by pass spring off but you have to know your engine to do that.
Back quite a few years guys used to put an adapter on for a fram HP100 that might be the case here but I would just put the stock adapter in and run a wix 51060
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-22-2009, 01:24 AM   #4
Captainfab
60-66 Nut
I believe that number should be 51061
Old 12-22-2009, 01:42 AM   #5
62gmc910
62gmc910's Avatar
Captn's right 51061 by application 51060 has antidrain back and cheaper from my sources I have a lay down filter truck this way I can just remember 1 number (I got a few hours on my memory )Also I-6 guys the 51060 is the way to go for the semi horizontal position
But thank for checkin ,Captainfab, If I put some info that sounds weird it's always best to have a second opinion
