Old 12-22-2009, 11:52 AM   #1
gator2511
gator2511's Avatar
Really Noisy Suspension
My 72 K10 sounds like a bucket of bolts coming down the road. Its one of those things that came on gradually so I didn't get irritated about it for a while. The noise seems to be coming from the springs. Its like a metallic slapping noise. Seems to happen on small bumps as well on the big ones. I hear it from the front and rear. Do these 4wd springs do this when they age and wear? I don't remember this much noise in the past. I have replaced the spring bushings and checked everything for being tight but can't find anything loose. The shocks and bushings seem good and there is no slack or play anywhere. Did Chevy put anything in between the leafs to dampen the spring noise? The glovebox door label says I have a heavy duty spring on the front.
gator2511 is offline   Reply With Quote
Old 12-22-2009, 08:40 PM   #2
JimKshortstep4x4
Re: Really Noisy Suspension
Make sure your spring stop is not to close to the spring on the front spring driver's side.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-23-2009, 04:52 PM   #3
gator2511
gator2511's Avatar
I'll check er out!
