Old 12-22-2009, 12:26 PM   #1
Anadrol
Anadrol's Avatar
Wind Blows the Side Mirrors out of Position
As I'm driving, my side mirrors (OEM replacement mirrors bought from LMC) fold inward because of wind.
Any ideas on how to make them tighter so that they won't do this?
Anadrol is offline   Reply With Quote
Old 12-22-2009, 01:33 PM   #2
cjracing15
cjracing15's Avatar
Re: Wind Blows the Side Mirrors out of Position
If they are dumbo mirrors just take the bottom cover off and then you will see a tighting bolt for this very thing.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 12-22-2009, 01:57 PM   #3
3r!c84
Badass
3r!c84's Avatar
same problem with mine..but only at highway speeds
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-22-2009, 03:26 PM   #4
78 Chevyrado
If the bolts just wont tighten up enough to hold them, you may have to scuff them up a bit where the two pieces contact to give them a little more friction.
78 Chevyrado is offline   Reply With Quote
Old 12-22-2009, 09:52 PM   #5
thrtsxchambers
thrtsxchambers's Avatar
Same problem here but mine are the stock small mirrors, I close the door and they move. I was going to replace them with the ones from lmc but may look somewhere else.
thrtsxchambers is offline   Reply With Quote
Old 12-23-2009, 01:39 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Put a screw through the shaft. I had 91 Dakota with the same problem. I removed the mirror and wrapped the shaft with duct tape. I tightened the screw down and it worked.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
