12-22-2009, 01:43 PM | #1 |
Need help...again. Frame question
Im gunna go work on my the ole 67 today but before I head out there I want to swing in and get some sheet metal and some metal to make the rear most xmember since mine was scraped. I hate that I cant just go out and take the measurement for myself since the truck is 20 miles away. I plan on getting about 34 inches long so I have some room to trim to fit but I need to know how tall the frame rail is from the inside edge to inside edge where the rear xmember rivet hole is. Anybody? I searched and searched but just was having no luck. Thanks a million.
Todd project "FED UP"
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
12-22-2009, 01:58 PM | #2 |
Re: Need help...again. Frame question
12-22-2009, 05:09 PM | #3 |
motor exploder
i have the bed off my truck now, I can check when I get home this evening, if no one beats me to it.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 12-22-2009 at 05:10 PM. |
12-22-2009, 07:40 PM | #4 |
Thanks for your willingness to help. I made it to Pacific steel earlier today and just picked up a 10'x4' sheet of 18 gauge cold rolled steel. I'll get the metal for the cross member another time. Although I made it out to my truck and took a quick measurement. Its roughly 4" from the inside bottom to the inside top of the frame with the frame thickness being 3/16s, over all frame height of 4 3/8" at the rear. Thanks again and keep on truckin!
12-23-2009, 01:09 AM | #5 |
motor exploder
yeah, I just got in and checked mine right in front of that last crossmember and it is 4.25" top to bottom on the inside of the 'rail.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
12-23-2009, 11:30 AM | #6 |
Is this the crossmember you mean-all the way at rear,has a hole for the taillight wiring harness to go through?
