12-22-2009, 03:33 PM | #1 |
My New 1969 Custom 10 Project
Last weekend I purchased a 1969 Custom 10 off of Ebay for $585. Suffice to say this baby needs a good amount of work. Cab corners, floors, bedsides, rockers, etc all have rust.
It was advertised on Ebay as a 350, but after careful investigation it is an original 307. Some vital stats on the truck. True mileage: unknown. Odo reads 59k, but I am betting it turned over. 1969 Custom 10 Long Fleetside Bed Model: CE10934 From the production numbers thread CE10934 Fleetside 8ft ,$2569 Price, 3623Lbs, 268233 Built VIN: CE1491..... Type - C - Conventional (2WD) Engine - E - V8 GVW - 1 - 1/2 ton Body - 4 - Pickup with cab & bed Year - 9 - 1969 Plant - 1 - Oshawa SE: (not sure what this is, can anyone enlighten me?) FT0690576 Paint / Interior 544 White/Red 618 Red Custom Cloth Trim Options A11 Tinted Glass B85 Body Side Molding BX2 Body Side Molding - Wide D36 Non Glare Mirror DG4 Below Eye Level Mirror D99 Two Tone Paint Moulding G50 Heavy Duty Rear Springs J70 Brake Booster Equip N40 Power Steering O63 Radio-Push Button P03 Chromed Hub Caps P47 15 x 5.5 Wheel V37 Chrome Bumper FR&RR Z53 Ammeter - Oil Guage Z62 Custom Comf&Conv Equip Chevy 307 : block casting 3956632, heads 3927185 Rochester 2-Jet - 7029105 Tranny : 3 on the tree - no numbers yet Rear End: Looks to be a GM 12 bolt rear, numbers soon. The dash wiring had caught on fire in the past and was basically destroyed. Luckily the ends on the harness and fuse block were still intact, so I spent this past weekend repairing the harness with new wire and some new ends. As of now I have all of the electrical in the truck functioning and the motor starts and runs very well. The shift linkage is very tight when you try to pull it back toward you to shift it, so I will be working on that situation next in order to be able to test out the tranny. Lots of sheet metal arrived in the mail over the weekend, so I will be busy on that for the forseeable future. The only pics I have at the moment are the ones from the auction(see below). The one strange situation I will need to deal with is that at some point a sport truck wheel was installed. Still deciding what to do on that. I would like to restore the truck to original, but that may be a little too ambitious for me. We'll see how it shapes up as I move forward on the project. Last edited by w3lfd; 12-29-2009 at 07:19 PM. |
12-22-2009, 03:49 PM | #2 |
Sofa King Crazy!!
Re: My New 1969 Custom 10 Project
Good deal! Too ambitious....no such thing. Welcome!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
12-28-2009, 02:35 PM | #3 |
This weekend I removed the steering wheel and turn signal assembly. I sprayed the shift linkage with WD40 and worked it back and forth a few time and voila! - works like a charm.
After this little project I removed the windshield (damaged by the dash fire). The top corners have the typical rust. The passenger side more so that the DS. This evening I am picking up a rusty '71 3/4 ton with a 350 / 4 speed that will be providing a windshield and various sheet metal for this project. At 300 bucks I could not pass it up. Pics to come soon. Last edited by w3lfd; 12-29-2009 at 07:20 PM. |
01-25-2010, 07:33 PM | #4 |
Rust repair on the '69 is now in progress....
01-25-2010, 07:42 PM | #5 |
67cheby
i think with the rust along the back of you cab floor , your truck would be a shoe in for the whole cab floor replacement.. If they would have had the complete floors when i did mine i would have gladly gone that way i think it would take less time than patching the rest, i know you didnt ask just my 2 cents
01-25-2010, 08:16 PM | #6 |
I have another cab with rust in the front, but that whole section is clean. The rear support and floor are going to be coming from that cab. Thanks for the input, though. I did think about going that route. But I got a whole truck for 300 which will help me repair the rear floor area, the top of the window area, and the bedsides, as well as providing a clean grill and window glass.
It's crazy, but all of the areas I need to patch the 69 are clean on the 71, and the rest of the 71 is a rust bucket. Last edited by w3lfd; 01-25-2010 at 08:22 PM. |
01-31-2010, 03:46 PM | #7 |
I got some more work on the passenger side done this weekend. Also dug up a pic of the cab corner before it was repaired.
02-09-2010, 09:53 AM | #8 |
Sofa King Crazy!!
Love the smell of rust repair in the morning. Good score on the $300 truck, keep going!!
02-09-2010, 11:23 AM | #9 |
Thanks for the encouragement. I need all that I can get
02-09-2010, 11:55 AM | #10 |
Nice truck you got there, and 2 of them for 900 bucks, sweet, part one out and make one good one, make some money back. I look forward to seeing some more progress. Just do not get worked up over small things, sit back and enjoy every minute you are working on it, remember it is a hobby and enjoy it. Congrats.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-10-2010, 12:21 PM | #11 |
Finished all of the major welding on the passenger side and cut apart the driver's side. I was in such a groove with the nice weather and all that I went ahead and welded the driver's side cab corner in as well....
07-13-2010, 08:10 PM | #12 |
Been awhile since I have updated the thread. Got all of the cab work done for the most part, and it's on the road now. Gave it an interim coat of semigloss black until I can get the bed sides welded and start working on paint prep.
07-19-2010, 07:43 AM | #13 |
I started the rust repair on the bedsides. The sections came out of the donor '71.
07-24-2010, 06:07 PM | #14 |
After all the fun. All that's left on the sides is sand and paint. Still a lot to do on the inside of the bed.
12-30-2010, 09:44 PM | #15 |
nice work, that's was alot rust, good job keep on truckin''
12-30-2010, 09:50 PM | #16 |
VA72C10
any recent updates? a lot of good progress was already made...
Looking for a 67-72 swb or blazer project in or around VA. |
01-02-2011, 11:27 PM | #17 |
I put some buckets in it: http://67-72chevytrucks.com/vboard/s...d.php?t=426349
Pulled the tired 307 and did it up: http://67-72chevytrucks.com/vboard/s...d.php?t=434462 I am in the process of getting ready to do some more body work and sanding / painting. |
01-20-2011, 06:26 PM | #18 |
cool!!!! keep on truckin''
