Old 12-22-2009, 03:34 PM   #1
blackmopar
steer box for the 64
I have a 64 lwb. The power sterring box I have doesnt appear to be the right box for my truck - the PO welded some steel plates to the frame rail and has this power box bolted onto the plate with steel spacers - so the box doesnt look like it bolted directly to my frame in other words.
Id prefer to go with a manual box to run 1 less accessory belt - but the only box I find fro Gm is the '525' box that is like $250 bucks!?!?
First question, Is that the right box for our trucks? Anybody have a source for them?
***Please know I am not posting this as a WTB thread
Thanks for any advice/guidance guys!!!
blackmopar is offline   Reply With Quote
Old 12-22-2009, 06:38 PM   #2
blackmopar
Re: steer box for the 64
poking around, maybe I just need to use one of these brtackets from CaptainFab instead of the mish-mosh the PO tried using. I still dont think I want to run power though, but it seems thqat these boxes are used for manual or power - does that mean they have the same gearing inside? if so i wonder if I can just block off the hose bungs and run without a pump????
http://67-72chevytrucks.com/vboard/s...d.php?t=332923
Old 12-22-2009, 10:11 PM   #3
TR65
TR65's Avatar
Hey BlackMopar,
You need to use a manual box if you are going manual. The "gearing" is not the same and would be very difficult to steer without the hydraulics. Here is a picture of the manual box for a 65, should be the same for 64.
http://67-72chevytrucks.com/vboard/s...d.php?t=374519
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-23-2009, 02:08 AM   #4
62gmc910
62gmc910's Avatar
IF you choose to go with on of Captainfabs plates you can use a manual box box from a 67 to 87 2wheel drive it mounts the same as the power box and is a far better design than the origonal 64 box
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-23-2009, 12:47 PM   #5
blackmopar
b1tchen - appreciate the info guys - thanks
Old 12-23-2009, 01:25 PM   #6
blackmopar
Originally Posted by TR65 View Post
Hey BlackMopar,
TR
Yea I figured the gearing would be different. And also the more I looked into i realzie the boxes arent the same.
