oil from my header
ok so lately my truck has been running funny, today i went to change a header gasket and i noticed oil from the front hole where the header is. anyone know what might be causing this? its a mall block 350.
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
Re: oil from my header
The oil is in the exhaust port of the head? Just trying to clearify, not be a questioning donkey. I'd check compression on that cylinder too.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
yeah, i have no idea about engines man
My mechanical brain has rotted over the past 10 years from not working on vehicles on a regular basis. I'd say it could be head gasket, rings, valve seal, or something else I'm forgetting. Note: I'm not saying it's a definate on any of them but they are the most lively culprits.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter Last edited by Adams74Chevy; 12-22-2009 at 06:04 PM. |
is it expensive?
It depends on what is the problem. I'm sure there are some others on here that can give better ideas and help troubleshoot it. You may even want to post this in the Engines forum, it may get more reads and info.
will do thank you
Badass
do it smoke (white smoke) when you start it up and then stop? or just keep smoking out the tail pipe?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
its smokes when i start it up and when i come to a stop.
id say rings probably
Your piston rings and valve seals are most likely the culprits...
are they replaceable? sorry, i know nothing about engines and im at a loss. i start school on monday and am hoping to get this resolved by then
#13 |
Still plays with trucks
So it is the front bolt that attaches the header to the cylinder head that is leaking oil?
These are blind holes so the only way that could happen is to have a cracked cylinder head. Somebody may have put a bolt in there that was too long and tightened the snot out of it trying to get it to seat the header. You may be able to just put some ultra black or copper RTV on the bolt threads and stop the leak into the headers.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#14 |
no not the bolt hole. just the big hole where air flows through the header.
#15 |
The way I read it. He was talking about oil residue in the exhaust port. And with the way he says it smokes on start up and when its running it makes me think a mixture of valve seals and piston rings.
#16 |
which is easier to check? and how do you do this ?
#17 |
A compression check will be the quickest and easiest test to do.
If all the cylinders are within about 10% of each other then a leak down test is next to see if you have other compression related issues like a damaged ring, piston or valve. If the compression and leak down tests are consistent then it is most likely just bad valve stem seals. With the age of our trucks you are guaranteed to have old petrified damaged and non-functional valve stem oil seals but the guides themselves may be in decent shape. My truck smoked a little on start up before I changed out the valve stem seals and now it doesn't smoke at all. Get a set of 16 silicone umbrella style valve stem seals that have springs around the top edge to hold them tight to the valve stem. While you are at it get a set of Z/28 replacement valve springs. They should cost you about $40 out the door for the seals and springs at your local machine shop. It's not the easiest job to do with the heads on the truck but it can be done.
#19 |
ok any one got any pics of this? or an explanation to to replace?
#20 |
Badass
umm no i dont,its in the head what the valve rides into is leaking.its like a .25$ part but a longass time to replace it lol..trying to figur out the new change in this website!!!?
#21 |
hahaha dang this sucks. i hope thats it. would this cause it hen im driving to be more sluggish? cause it donmt feel like i have the power i had before i had this problem?
#22 |
Badass
no it shouldnt realy change that..i had a atc that would smoke out the garage when i first fire her up.it would only smoke for 2 mins and then run good
#23 |
dang. this suck....
#25 |
i wish i had a heated garage.
