Old 12-22-2009, 08:12 PM   #1
Sicboy
Sicboy's Avatar
Window Regulator Replacement
What is the procedure to remove the driver side window regulator of a '66 C10? I removed the screws holding the regulator and window channel to the door, but the forward window channel will not allow the removal of the regulator. Do I have to remove the window channel? If so, It appears the vent window assembly is holding the window channel in place...how do I remove it? Does anyone have a scan of the service manual pages covering this procedure?
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 12-22-2009, 08:57 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Window Regulator Replacement
You have PM.
Old 12-23-2009, 09:03 PM   #3
Sicboy
Sicboy's Avatar
Got er done. Had to remove, the vent window assembly and the window first. Thanks for the info Mark.
Old 12-23-2009, 10:19 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
I'm going to do one of mine during Christmas break. Did the window come out of the track easy, or was it wedged in real tight?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 12-23-2009, 11:22 PM   #5
Sicboy
Sicboy's Avatar
You have to remove the vent window assembly to remove the window. Here's what I did:
1) Lower window to bottom.
2) Remove armrest, window crank and door handle.
3) Remove door panel.
4) Remove 4 regulator mounting screws and 2 lower window channel screws.
5) Remove vent window screws (located through door frame)...mine had 4
screws.
6) Lean vent window frame into cab then pull up and out.
7) Slide regulator out of guides.
8) Remove window.
9) Remove regulator.
10) Reverse steps 1-9 to install new regulator.
The toughest part of the whole operation were the door panel screws. I had to drill out three of them...and those fuggers were hard steel. Ruined several bits.
Good luck!
Old 12-27-2009, 05:09 PM   #6
ol Curt
Junior Member
ol Curt's Avatar
I worked on one of these today. I find mine is binding a bit when I put the window back in. I'm getting ready to take it all apart again. I suspect 90% of the problems with these aren't from the regulator itself as much as alignment of all the components that hold the window in place.
Can someone tell me if the piece the widow glass fits into should be centered on the bottom of the window? I'm wondering if that may be part of my issue.
Old 12-27-2009, 09:18 PM   #7
ol Curt
Junior Member
ol Curt's Avatar
Realized a pic is worth a 1000 of my words.
Here is the channel I'm talking about. Should it be centered on the window when I put adhesive on it?
Old 12-28-2009, 11:01 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
Buehler??
Old 12-28-2009, 11:24 PM   #9
Sicboy
Sicboy's Avatar
Wish I could help ya Curt...my door panel is back on, so I can't take a look at it. I didn't remove the channel from the window. Can you look at the other door?
Old 12-29-2009, 12:16 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
It's been years since I pulled the windows in mine but I'm almost certain the track is centered on the window. I agree with Sicboy, I'd pull the panel on the other door if that window is functioning correctly and confirm, before gluing it together.
Old 12-29-2009, 01:19 PM   #11
ol Curt
Junior Member
ol Curt's Avatar
Found the channel goes to the BACK of the glass.
Now I'm worried about how tight (or not) it will fit in the channel with just 3m sealant. It had a rubber channel in there when I took it out, but it was so hard and crumbled I doubt it was doing much. I removed all of it. I don;t see it offered for sale on any of the sites so I'm going to assume the weatherstrip adhesive is suffucient.
Old 12-29-2009, 09:12 PM   #12
ol Curt
Junior Member
ol Curt's Avatar
For those who might be pondering this I found some tape I think is supposed to be used for this. Some guys on an other forum gave a little insight.
http://www.classicparts.com/1964-66-...ctinfo/70-721/
Old 12-29-2009, 09:24 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
I would definitely use the tape designed for the purpose. Otherwise the glass may be pulled out of the channel at some point in the future and fall into the door.
