12-23-2009, 09:34 AM | #1 |
Cab undercoating ?
When I get my cab back from the body shop I wan to undercoat the bottom of the cab whats best to coat it with? would undercoating in a can work or something like por15 or maybe a brush on bed liner matrial work better? Just need some feed back and pictures would be great.Thanks Brandon
Brandon |
12-23-2009, 10:23 AM | #2 |
Spanked once
Re: Cab undercoating ?
Here is a picture and answer.
http://67-72chevytrucks.com/vboard/s...2&postcount=11
The ole 350 budget build. |
12-23-2009, 10:54 AM | #3 |
Active Member
Back in my growing up years in the 50's and early 60's a lot of vehicles were treated with "undercoating." A material similar to bedliner. I hated the stuff.
The main reason I disliked it was that after years of use and sheet metal being flexible, it would crack and allow moisture, dirt or salt spray to get into the crack and rust the metal unseen. Also the stuff looks ugly. My 68 GMC has the stuff under the wheel wells front and rear. Still rusted along the edges. In my opinion, one would be better of using a tough paint like Rustoleum or similar. It would be easier to see any damage and repair it. |
12-23-2009, 01:48 PM | #4 |
Parts and more parts
Have you consisdered "Lizardskin"? It is a relatively newer product, but is good for sound deadening and heat transfere issues.
www.lizardskin.com
Frank |
12-23-2009, 02:43 PM | #5 |
TOTY 2006
I had my cab and wheelwells done by SpeedLiner
12-23-2009, 03:14 PM | #6 |
I used POR 15 on my cab
12-23-2009, 05:06 PM | #7 |
Ok thanks for the help guys
Brandon |
12-23-2009, 05:16 PM | #8 |
ALs liner is a good product for that, It's pretty reasonable also.
Check my sig.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
