Old 01-24-2003, 07:35 PM   #1
fleetside72
Unhappy another 93 S-10 problem
I have a 93 S-10 club cab,,,,,the problem is with the heater,,I think,,,,when it's cold out ,like now,i let the truck run for about 10-15 minutes,,,,,when i get in the truck,,,,,the defrost isn't working,,,i have to bang on the dash to get it blowing,,,,also today,,,i was sitting in my truck with it running,,,,the blower cut out then on,then out then on,,,when it cuts out,,the brake light comes on too,,,also the speedometer is cuttting out now too,,,,,,,Doe's anybody think it is the heater switch,,,,it is a 2.8,,,if that matters,,,,THANX for any help!!!,,,,Dave
fleetside72 is offline   Reply With Quote
Old 01-24-2003, 11:25 PM   #2
Piston
Piston's Avatar
Sounds like a ground problem of some sort. Check your connections at the blower motor, make sure the ground is secure.
Piston is offline   Reply With Quote
Old 01-25-2003, 07:08 PM   #3
kendog
Pistons probably right. I have a 94 -1500 and when i first got it I would get on the gas and it would start cutting out,my speedo would go past 85 and my radio would cut out. I thought it was a tranny problem and I finally took it to the dealer for thier 65 dollar electronic check out fee only to find out my battery cable ran up by the exhause and was shorting out under heavy acceleration.They rerouted my cable and all has been fine since..................
If your not the lead dog, the view never changes.
kendog is offline   Reply With Quote
Old 02-09-2003, 02:39 AM   #4
fleetside72
Another 93 S-10 problem
i finally found out where the problem was on my S-10,,,it is in the switch!!!!......the brake light would come on and the fan wouldn't blow,,,,all i did was turn the switch ahead just a touch,,,,,What a Relief and THANK GOD!!!
Old 02-10-2003, 12:49 AM   #5
Pudd_Dogg
WELL WELL WELL
Pudd_Dogg's Avatar
LOL good fix ....and didn't have to bust the wallet
Pudd_Dogg is offline   Reply With Quote
Old 02-10-2003, 08:31 AM   #6
rkwblzr
I agree with the reply that you may have a ground problem. I have an '88 GMC that had a ground wire under the dash close to the parking brake that got loose and you will get all sorts of strange happenings. With the amount of plastic used in todays dashes the ground is much more critical. There should be an instrument ground under the dash and one under the hood that connects the body to the engine. Good luck!
rkwblzr is offline   Reply With Quote
