Old 12-23-2009, 01:50 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
How to Paint GMC Gauge Bezel
The face of GMC gauge bezels are painted a contrasting color to the interior (instead of black like on the Chevys). What is the best way to replicate this? Find a close rattle can color? Buy a chrome bezel (don't have to worry about fully covering the black)? Use blue painters tape for masking?
I'd like to hear from anybody who has done this before I risk a $50 bezel.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-23-2009, 02:20 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: How to Paint GMC Gauge Bezel
I would first try a close rattle can first depending on your color. It is not hard to paint the black area. What I do when I paint 67-68 bezels is paint the silver first, then I use masking tape and cover all of the silver areas, then I use an exacto knife around all the gauges. Make sure you have new razor blades for the knife, and cut with not a lot of pressure around them. Then it's time to shoot. I usually spray Krylon fusion, because it's made for plastics, but the chances of you finding a really close color in fusion is slim. What I would do in your case is get some Bulldog adhesion promoter once you mask off everything and mist coat where you want paint, then wait 10-15 min. and spray your color in mist coats. You don't want to rush the color as you can make the grain disappear. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-23-2009, 02:21 PM   #3
71blksuper4x4
SWB 4x4 Collector
If you use blue painter's tape, make sure you get 3m. The cheaper stuff doesn't stick very good at all, and you don't want paint to get under it. Trevor
TREVOR
Old 12-23-2009, 02:23 PM   #4
71blksuper4x4
SWB 4x4 Collector
Here's an example of a painted dash I did:
TREVOR
Old 12-23-2009, 03:43 PM   #5
badpeanut
badpeanut's Avatar
71blksuper4x4, that looks really nice! Is the silver Krylon fusion also?
Attached is a picture of my dash and how the chrome looks tired. I wonder how it would look if I just painted my chrome areas with silver like the '67-'68 you pictured?
'70 GMC LWB trailer
Old 12-23-2009, 04:27 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
I did this on my 69 GMC bezel (green). The old one was starting to show its age. I took a "All Chrome" bezel and started to mask of the chrome. Unfortunately it is almost impossible to do the little chrome lip but do the best you can. I then sprayed with the closest rattle can color green I could find and it was a 99% match. 5 min after spraying I took the masking tape off and wiped the paint off the chrome rings with solvent(Brake Clean or Varsol) carefully before the paint dries and is still soft. Using a nice lint free rag(t-shirt). It takes time but I was picky(OK I'm very picky) and I think it turned out great. I can post pics if you want when I get home
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-23-2009, 08:22 PM   #7
71blksuper4x4
SWB 4x4 Collector
I didn't have an old silver painted bezel to go from until I had go my NOS Cheyenne Super woodgrain bezel to compare to. This was painted before that, Krylon fusion doesn't make a close match to that color but it was the closest I could find in fusion to paint it. I have since painted another bezel that matches the silver perfect. It is SEM silver. When you spray it though, mist coat it until it reaches a good uniform color, then pull back from the bezel (after dry) and spray almost a foot away. This will create the slight texture the original silver bezels have. I will try and get pics of it to compare the colors to. Trevor
TREVOR
Old 12-23-2009, 08:23 PM   #8
71blksuper4x4
SWB 4x4 Collector
I forgot to mention, the letters on the lights and wiper are redone with a silver paint pen/marker. Trevor
TREVOR
Old 12-23-2009, 08:25 PM   #9
71blksuper4x4
SWB 4x4 Collector
Oh, and I didn't use blue painter's tape, I used 2" 3m masking tape on the ones I have painted. Trevor
TREVOR
Old 12-23-2009, 08:45 PM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
Here ya go.... the last one is the factory original
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 12-23-2009, 10:51 PM   #11
The bezel color matches the interior and contrasts the exterior,right?I get paint mixed to match made up in a spray can.If you mask over the openings,then cut tape outside the lip it works pretty well.I`ve wiped a light amount of Vaseline across the lettering then wipe it off immediately after painting.
