![]() Join Date: Dec 2008
Best way to repaint 69 and 70 grill
Ok I had my grill polished and looks rather nice but now the black paint is gone what is the best way to redo this so it doesn't look cheap or shoty?
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
Re: Best way to repaint 69 and 70 grill
ok i primed it with rattle can rustolium automotive sandable primer after i taped up the chrome then i painted it blue with tractor enamel. i like it but if it chips easy. it works for me though
You want to tape off what you dont want painted scuff it up where you want paint i would use barrel black from summit racing it gives a satin look not to flat and not to shiny paint it put a good 3 layers with a flash time of 15 min between coats should look great and not chip
Be sure to use either the blue or green masking tape they leave a nicer looking edge
SWB 4x4 Collector
![]() Join Date: Jun 2001
If you decide to rattle can, I would choose a lacquer paint. The factory would have used similar back in the day. If at all possible, get paint mixed up that's a two part paint and spray out of a gun. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
It takes a lot of time but if you tape it off really good with that blue painter's tape it will come out pretty good with spray paint:
Before: ![]() After: ![]()
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 12-27-2009 at 09:25 PM. |
Suburban Hick
![]() Join Date: Aug 2008
This might sound cheap and lazy, but they make black decals that fit in the letter spots.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
Tot Roddin'
It takes a lot of time, but in the end it is so worth it. We did the same project on my '69 this summer, and after an hour or two of taping, followed by prep and paint, it looked like new!
Check out page 9 of my build thread... http://67-72chevytrucks.com/vboard/s...=353633&page=9
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
![]() Join Date: Apr 2008
I had mine polished this summer and had the same issue, the guy at the polishing place said to just prime and spray it, then take a block of wood with a paper shop towel wrapped around it, and spray it with WD40. while the paint is still wet rub straight across it and it will leave a perfect line w/o having to tape everything off.
Now all that said, I have not tried it yet, it seemed plausible but I just haven't done it yet. I have used WD to clean rattle can over spray before but not in this instance. I asked if brake cleaner would work better because it does not leave a residue but he seemed to think it might dull the shine.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
