Old 12-23-2009, 08:15 PM   #1
halfcockedcustoms
halfcockedcustoms's Avatar
got more go,,now need more whoa
I have finished my t5 install in my 64 and love it,,Now my question for you guys is,,I want to upgrade my brakes a lil,,sticking with drums front and rear for now but want to add a daul pot master cyl,,,what would be the best way to go with this?I have no idea where to start,,did a search and chouldnt really find what I was lookin for,,,,Thanks
halfcockedcustoms is offline   Reply With Quote
Old 12-23-2009, 08:17 PM   #2
19GMC63
19GMC63's Avatar
Re: got more go,,now need more whoa
http://67-72chevytrucks.com/vboard/s...d.php?t=332148
19GMC63 is offline   Reply With Quote
Old 12-23-2009, 11:23 PM   #3
slepysal
slepysal's Avatar
so tell us about the t5 install
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-23-2009, 11:47 PM   #4
halfcockedcustoms
Originally Posted by 19GMC63 View Post
thanks
Old 12-23-2009, 11:49 PM   #5
halfcockedcustoms
best advise I can give is do ALOT of readin the techs on them,,,and take your time,,Mine had a few setbacks, but is way worth it
Old 12-24-2009, 12:11 AM   #6
19GMC63
19GMC63's Avatar
what's the T5 behind?
I have a T5 behind a mild 350...I'm just waiting for the day it snaps. That's ok though, it was cheap.
Old 12-24-2009, 12:36 AM   #7
halfcockedcustoms
mine is behind a 250 6cyl
Old 12-24-2009, 01:49 PM   #8
ravens65
ravens65's Avatar
drum brakes are a thing of the past my friend, installed 4 wheel disks on mine . master cyl. and front are from CCP and the back is from a rear end swap w/ a Trans/Am this also gave me a 5 lug pattern , its hard to find nice 6 lug rims. also went with front and rear sway bars when I did my drop kit ( all CPP) this handles like a new car and stops on a dime . instead of the front diving the whole truck does , well worth the money and gets rid of the old truck feel Eric
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline   Reply With Quote
Old 12-24-2009, 02:08 PM   #9
Chevysdominate
Chevysdominate's Avatar
I always thought adding hydro-booster to an old, but properly maintained set of drum brakes would be killer. No need to change to 5 lug or anything else. Adding hydroboost isn't trivial but it would turn an drum brakes into something very nice.
Chevysdominate is offline   Reply With Quote
Old 12-24-2009, 02:08 PM   #10
62gmc910
62gmc910's Avatar
If you really want to stay drum I am pretty sure that the wider drums and backin plates from a mid 70s 4X4 will fit but before you go buy it all check to see if the drums fit your wheels and if you can fit the backing plates on the front. I did a disc conversion on the truck in my avatar back in the early eighties cause drum brake and a 500 horse big block don't mix
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-24-2009, 04:23 PM   #11
halfcockedcustoms
sounds like alot of money I aint got to spend and the drums have worked for 40 years
Old 12-26-2009, 01:05 AM   #12
Captainfab
60-66 Nut
Yes they will fit on any truck 12 bolt except for the '63's that had pressed on backing plates. With the 1/2" wider shoes this upgrade will give you better braking on the rear. I don't know if the backing plates could be made to work on the front or not.
I would also suggest upgrading to a power brake booster with a '67-'70 dual resevior master and acompaning metering valve. This can be done reasonably with off the shelf parts from your local auto parts store, or from a wrecking yard. There's absolutely no need to buy expensive aftermarket brake parts unless that is what you want. There's plenty of OEM parts that interchange.
