Old 01-24-2003, 08:14 PM   #1
Tim Christian
Tim Christian's Avatar
Smile Hey Racing29!!!!!!!!!!!!!
Hey Racing29, If you are going up Interstate 81 North go untill you come to the Interstate 181 South exit 46 take it and go toward Johnson City you will then go to the Gray Exit 42 Look for the Appalachian Fairgrounds signs that will take you right to it.
You can also go up 11W like coming to Rogersville but keep going to Kingsport and take the Interstate 181 Exit it is at the third red light past the new Wal-Mart in Kingsport When you get on 181 go south or towards Johnson City you will then go to the Gray Exit 42 Look for the Appalachian Fairgrounds signs that will take you right to it.
I edited these directions from last night I was a little off but not much I also added the Exit numbers. when you get off on the Gray exit 42 they are signs up they say Swap Meet just follow them and it will take you right to it I am in the second building stop in and say Hi!
Tim Christian is offline   Reply With Quote
Old 01-24-2003, 09:41 PM   #2
RACING29
Thanks I'll see you there!
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
