Old 12-23-2009, 10:15 PM   #1
killacheyenne
killacheyenne's Avatar
squeaky coil spring
my front right coil spring is very sqeaky and i was wondering if there was anything i could do to help this since i have to drive down 2 miles of dirt road everyday
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 12-23-2009, 10:50 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: squeaky coil spring
There may be a piece of rubber that works as an isolater. After a while, the rubber will deteriorate or wear in two. You will need to split the a arms. On my truck, I didn't have to compress the spring, I just ran a ratchet strap through the center for safety. I jacked the truck up, put it on a stand, put the floor jack under the lower a arm, raised the jack until it just was about to lift the truck off the stand, loosened the lower ball joint bolt, whacked it with a hammer til it came loose, then let the jack down til I could pull the spring.
WIDESIDE72 is offline   Reply With Quote
Old 12-23-2009, 11:02 PM   #3
71tahoe
71tahoe's Avatar
I've pulled apart 3 front ends and have yet to find a rubber isolator and none of them squeaked. Have you liberally greased both ball joints and both ends of each a-arm? Just for good measure hit the inner and outer tie rod ends.
71tahoe is offline   Reply With Quote
Old 12-23-2009, 11:25 PM   #4
cdowns
cdowns's Avatar
anothe thing to check is the shock absorber mount//the stud thru the frame rail will loosen up elongating the hole allowing movement and squeaking
Old 12-23-2009, 11:25 PM   #5
killacheyenne
i greased everything posible today and it steal sqeaked loud. i felt the spring as i would push down on the hood and it felt as if the noise was coming from the coil itself
72 cheyenne super
Old 12-23-2009, 11:30 PM   #6
Dark Knight
Dark Knight's Avatar
Did you check the bushings on the lower control arms? They're probably dry-rotted.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 12-23-2009, 11:43 PM   #7
Boog
laying low
Boog's Avatar
If it's still a stock spring it fits so tight it's not likely to be the cause of the squeak. More likely is ball joint, control arm, sway bar or shock mount bushings. Hit em one at a time with water or wd40 then bounce it a bit to see when the squeak stops then you'll find the source.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-24-2009, 12:19 AM   #8
byrd
Union Electrician
byrd's Avatar
I would bet the farm it is a shock, or a control arm bushing
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-24-2009, 12:52 AM   #9
AJLChase
AJLChase's Avatar
I was having the same issue as well, not only do I believe my control arms were rotted but, once I dropped the coil spring out I had found that a coil had actually broke off of the spring. That leads me to believe that it may also have been the source with the two coils rubbing against one another.
AJLChase is offline   Reply With Quote
Old 12-24-2009, 10:27 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
I assumed that the problem had already been diagnosed as a squeaky coil. In fact there are a lot of other possible culprits. I had a broken coil on my 79 Malibu tht would only pop when driving over speed bumps. I couldn't tell it was broken until I tore it down. I also had a 97 Chevy 1/2 ton that had a squeak. It ended uo being worn out sway bar bushings.
Old 12-24-2009, 10:29 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
It has been a while since I have had a 72 front end apart, but my Malibu had isolators front and rear.
Old 12-26-2009, 01:43 AM   #12
killacheyenne
i put new shocks on and it still is loud as ever
72 cheyenne super
Old 02-04-2010, 08:33 PM   #13
redssilverbullet
redssilverbullet's Avatar
is it a squeak or more like a ringing sound like it would sound if you hit the spring with a hammer but very fant mine has about the same thing and i can't find it ether mine didn't show up until i lowered the truck by cutting the spring
redssilverbullet is offline   Reply With Quote
Old 02-04-2010, 08:47 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They are steel. Dry rotting is for rubber bushings.
