12-24-2009, 09:18 AM | #1 |
225 60 15
anyone running this size tire or similar? i need to run a 25.7 in tall tire with the new tranny to make the gearing work out to what its set at at the factory (5.3 w/t56). tried search but its too difficult to search numbers. pics appreciated. thanks guys.
Jason Garverick 64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread 69 AMC Javelin 360/auto - 417 stroker (soon) 68 Scout (Basketcase) 06 Ram HEMI SWB Reg Cab Daily Driver US Army Vet |
12-24-2009, 11:23 AM | #2 |
Re: 225 60 15
What rear end ratio was that 'factory' set-up using? Are you also using the same gearing? That will affect the calculations.
12-24-2009, 11:31 AM | #3 |
Re: 225 60 15
If you go to tire mfg web sites they sometimes have the actual tire dimensions listed but they usually go by rolling radius and some even give revs per mile
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
12-24-2009, 05:39 PM | #4 |
Re: 225 60 15
sorry guys i guess i worded this strangely. i am considering running a 25.7 in tall tire. this is the stock tire height of a 2001 z28 that i'm pulling the transmission from. its also very close to a 225 60 15 overall height. both my truck and the z28 are running 3.73's. i'm trying to find someone that is running these tires so i can see what it looks like on our trucks cause i'm thinking they'll look too small and if they do then i'll have to start lookin for a set of 4.11's or 4.56's. i'd try it out myself but the truck is pretty disassembled right now. so if anyone is running something close to a 225 60 15 please post a pic and tell me how you feel about them. thanks guys
12-24-2009, 06:16 PM | #5 |
Re: 225 60 15
these are 235 60 15 / 295 50 15 only one size bigger
12-24-2009, 06:24 PM | #6 | |
Re: 225 60 15
I don't know of any trucks offered w/a 6spd (dbl OD) from the factory w/only 3.73's. Have you researched what drivetrain combos (motor, trans ratios, gearing, tire OD) come in full size trucks? I would steer my choices toward what a truck came w/vs. an f-body.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-24-2009 at 06:25 PM. |
12-24-2009, 09:59 PM | #7 |
Re: 225 60 15
Hey JG,
With the T56 you have so many gears that all a taller tire shoud give you is better gas mileage in 6th. I am running a T56 with 3:73 gears, gives about 1500 RPM in sixth at 70 mph with 235/75R15. Check out the Speed Analyzer at Keisler http://www.keislerauto.com/speed_analyzers.php?sa=gm_6 Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
12-24-2009, 10:06 PM | #8 |
Re: 225 60 15
Lower operating RPM's does not garantee better milage. Keeping the motor in it's peak torque range is ideal for efficiency. More than one board member has lost mpg's when swapping to OD w/less than optimal gearing/tire OD.
12-25-2009, 12:41 AM | #9 |
Re: 225 60 15
Scoti,
I am talking about highway cruising. I have driven LS motors with 6 speeds continuously since 1998. I currently get 23.5 mpg driving to work with a 430HP LS3. The key to good mileage with these engines on the highway is getting into sixth gear as quickly as possible. It is clear using a scan gage or the instant mpg readout. TR
12-25-2009, 01:03 AM | #10 |
Re: 225 60 15
thanks for the replies guys, i think i'm going to pick up a set of tires and try them out. if it runs well and looks good then i guess i'll stick with them. i've analyzed alot of gear ratios and tire combinations already and this seems the simplest way to go. i think its really going to come down to what the truck feels like in 6th gear on the highway. another thing i'm a bit worried about is how the truck will drive on state highways at around 60 mph.
@69gmc910 thanks for the pic man, what drop are you running? @tr65 how does your truck feel at 60? do you just use 5th?
12-25-2009, 01:28 AM | #11 |
Re: 225 60 15
[QUOTE=jgarverick;3692313]thanks for the replies guys,
@62gmc910 thanks for the pic man, what drop are you running? I really don't know I just swaped rear springs around until the tires didn't hit the box too bad (its a canadian GMC so its coil rear) and set the torsion bars to get the rake I liked . When I built it you could hardly get any aftermarket so it was just do what you could. I sure got some looks with the eightbolt wheels on a short box
12-25-2009, 01:37 AM | #12 | |
Re: 225 60 15
12-26-2009, 12:07 AM | #13 | ||
Re: 225 60 15
By the way you can go to a 255/60R15 and only make a 6% change in RPM. A tall tire like a 235/75R15 gives a 13% change. Not a big deal I think. Quote:
Cruising at highway speed takes only around 30HP. So the engine is going to run way below peak efficiency. As near as I can tell the MPG improves at these low HP levels down to around 1500 RPM and then is pretty flat. Another thing to think about. Regardless of power output the engine must inject enough fuel on each power stroke to actually fire (the reason DOD is used by GM). Downshifting is detrimental to fuel economy because the engine has to fire a lot more times at the higher RPMs rather than just reducing to idle. I always liked to downshift to "save the brakes" but it costs fuel. TR
12-26-2009, 01:13 AM | #14 | |
Re: 225 60 15
12-26-2009, 07:55 AM | #15 |
Re: 225 60 15
On my 63 C10, I'm running a 255/55/16" tire size. This size was the same height as the 255/60/15's" that I had on my rally wheels. I bought the General brand UHP tires. They are directional, very sticky and low priced from the Tire Rack. Here's a photo for reference:
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
12-26-2009, 08:53 AM | #16 |
Re: 225 60 15
Jason,
You are putting a lot of work into your truck and it has been first class all the way. With all due respect I think you kind of answered your own question. The 225-60-15 at 25.67 inches in diameter is a pretty small tire. It sounds like you are thinking it is too small and it is definately smaller than what the truck originally came with. Bigger - be - better in this case. For comparison a 710-15, which was stock on a 3/4 ton, and still didn't really fill up the wheel opening on our trucks, was 27.98 diameter. Your probably not going to be happy with this small of a tire. Nothing impacts the overall look of a project like wheels and tires. Fill up the wheel opening with a big diameter tire and wheel combo that you like. Then punch the numbers into a gearing calculator and swap out the differential for whatever fits the tranny / motor / tire combo. You will be glad you did. Last edited by lakeroadster; 12-26-2009 at 08:59 AM. |
12-26-2009, 02:27 PM | #17 | |
Re: 225 60 15
12-28-2009, 08:17 PM | #18 |
Re: 225 60 15
i think i have to agree guys. even with a mild drop (2.5/3) the tires would just look too small. however with a 3.73 gear and 275/75/15's i can turn about 1620 rpm at 72 mph which is about as fast as you can go in ohio without getting a ticket. if that lugs it too much, switching to a 4.11 gear would give me about 1800 rpm at 72. i guess we'll see
@1restorick how much drop are you running? that thing looks great man thanks for the brain food guys.
Jason Garverick 64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread 69 AMC Javelin 360/auto - 417 stroker (soon) 68 Scout (Basketcase) 06 Ram HEMI SWB Reg Cab Daily Driver US Army Vet Last edited by jgarverick; 12-28-2009 at 08:19 PM. |
