Old 01-24-2003, 09:13 PM   #1
SCOTI
SCOTI's Avatar
Help: ?'s about dually rears
Does anyone know the axle housing diameter of a stock 73 & later dually rearend? Are they bigger than 3" diameter tubing like similar year 12 bolt rears?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-24-2003, 11:00 PM   #2
MOUSE
the 73 i had was a 3/4 ton and it had the 14 bolt corporate rear end. the tubes WERE 3". hope this helps...1PHATC
MOUSE is offline   Reply With Quote
Old 01-24-2003, 11:05 PM   #3
SCOTI
SCOTI's Avatar
Hhmmm... my guess is the 14 bolt rear was pretty standard as far as packaging dimesions so the dually should be the same as the 3/4 ton.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2003, 11:16 AM   #4
Lester
The C30 and K30 dually rear ends were Dana 70's.
The C20 and K20 rear ends were mostly GM rearends, some were Dana 60's.
They are similar looking but are slightly different.
Lester
Lester is offline   Reply With Quote
Old 01-25-2003, 11:59 AM   #5
SCOTI
SCOTI's Avatar
I figure someone on this board has access to a dually to measure the axle housing diameter & hopefully confirm/deny the 3" diameter.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2003, 02:19 AM   #6
u2slow
Web Wheeler
u2slow's Avatar
The DRW Dana 70s used in the C/K30 pickups have a 4" tube on them. Other ones (mostly vans) have a 3.5" tube. 14FF's have a 3-3/8" tube
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
