c10 short bed build
figured i'd start my build page since its going to be an ongoing project.
its a 71 scsb c10 that has virtually no rust..its pretty clean.needed a tune up.had new interior.and a built up 350.barely ran when i got it and there were no brakes as you can see it was pretty disgustingly dirty wen i picked her up ![]() ![]() ![]() ![]() ![]() ![]()
71 scsb c-10 cammed full roller 350 lowered on 22's Last edited by GR$$N$; 12-24-2009 at 04:14 PM. |
Re: c10 short bed build
so i detailed it inside and out
![]() ![]() and also threw in a hella h4 conversion headlight kit and put one of my hid(im a dealer for them) kits into it.6000k ![]()
71 scsb c-10 cammed full roller 350 lowered on 22's |
then i decided to spend some cash on it.new brake lines,new brake pads and all new bushings for the calipers and spacers/etc.new bleeder valves.msd hei cap and rotor.msd 8.5mm wires.royal purple oil.fram filter.ac delco plugs.new belts.new harmonic balencer since the orginal one didnt have a bolt thru it so it flew off.i get the parts in the mail tonight so they will be going on this weekend.also took off the wheels and polished them up inside and out.also plated in the notch since the po had just torched out a notch
406 Powered
Love that truck.
70 GMC 68 c10 2002 silverado 72 4x4 |
Between Trucks...
Nice truck.
Beat it to fit, Paint it to match... ![]() |
Those headlights look good, what all is involved in putting that kit on
That looks like a comfort to drive.
thanks everyone!
well this is an actual plug and play hid headlight conversions kit. i then ordered an h4 hella conversion kit which instead of sealed beam it changes it to having a replaceable bulb and also better light output.and then my hid kit plugs right into where the oem hella bulb went and i connect the ballast to the stock 3 prong oem plug on the truck.they use less wattage than a halogen and also produce more light output and longer life
71 scsb c-10 cammed full roller 350 lowered on 22's Last edited by N2TRUX; 12-27-2009 at 10:35 AM. |
heres one hid in.dont have a pic of both yet.my comps only lettin me attach one pic unfortunately.still havnt found the virus yet
edit: oops,guess i already had added this picture before hand ![]()
71 scsb c-10 cammed full roller 350 lowered on 22's Last edited by GR$$N$; 12-28-2009 at 11:41 AM. |
heres the new painted front end.also cleaned up the engine compartment a little.got all the grease and oil off.still have to polish it all tho
first pic is of the water spots on the wheels.second pic is just a few minutes of polishing and third is completely finished
heres of the notch that was made from the first owner.this is it all sanded down and everything.i forgot to take pictures of the jagged torch marks and also the crack all the way up the frame.
![]() and it plated in.now mind you this is only temporary as im either doing a full frame or backhalfing it.so for the time being this is more than enough strength since i dont haul anything
#13 |
also took the plugs out and they're the blackest plugs ive seen in my life.threw the new ones in.threw in the new brake lines and also bled my system and it actually stops now which is nice.still havnt done the msd wires and jegs sent me the wrong cap and rotor so i have to wait to send it back and then get another one so progress is slow right now.also im going to have to order myself a new starter as this one is going.thats it for now
#14 |
dazed and confused
wow good looking truck!
members met: redbaron69, billsbowtie,nc67 |
#15 |
I vote to keep the bumper chrome.... I liked the grill chome too. but ehh thats just me. I do like the truck alot though! nice score!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
#16 |
thanks guys.and sinisterspeed, im just not a huge fan of chrome is why.the grille was majorly pitted and dented on one corner as well so the black looks way way better.and i just polished out the chrome a bit so it works for now.ill eventually do an older bumper with no lights and smoothed but i wont do that till i get rid of the mirrors,emblems,etc.
#17 |
Member of the longbed union.
man that notch looked hacked. Looked a lot better then my truck thought before I bought it. My buddy welded c-channel in it and it didn't work at all. cracked up the frame and half way across the top on both sides.
Your truck looks good thought. Cant wait to see your frame you build.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 12-30-2009 at 05:30 PM. |
#18 |
Grand PooBaa Member
Im sorry you said in the title, Short Bed Build. I guess my problem with that title is, it looks like the work has been done already. LOL
I can only speak for me but if my truck looked as ggod as yours, I'd be 3/4's done. LOL BTW, I work on pc's if you can go to www.download.com and download, Ad-Aware anti virus and Malwarebytes. Both are free and work great on stubbron viruses. Install Malwarebytes first, then run it complete. Then install Ad-aware, then run that after Malware. Should help, if not send me a message. |
#19 | ||
#20 |
not much of updates but got all the side marker lights and emblems taken off to measure up for some filler plates.going to cut those in the next few days(third brake light,front and rear side marker lights,all emblems and also mirrors) gas tank will wait until i come across a fuel cell.also ripped out the wheel wells to start preppin for the raised bed floor.also got all the msd stuff installed(cap,rotor,wires) and ran them alot cleaner than wat they were.also cut off the flowmasters and put on my 3" magnaflows.thats it for now
#21 |
decided to pull the valve covers last night and realized that the motor is a full rotor motor
#22 |
havnt been on here in forever.the c10 pretty much still sits as it is.i pulled off the suspension and "trimmed" it a little.got it down in the grass a little more.also sold the 22s. i pulled apart my sandrail for new paint and accessories but thats almost together again and then the c10 will be comin in to get cut up.also if you can see i put 05 chevy leather seats inside.once bagged ill work on the custom center console.im putting three 10" competition subs in the center so should sound decent
71 scsb c-10 cammed full roller 350 lowered on 22's Last edited by GR$$N$; 06-01-2010 at 11:12 AM. |
#23 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Nice lookin ride. I'm diggin the fact that you went back to 15's!
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#24 |
thanks! ive always loved 15s and i cant hurt these ones while im bagging it like the 22s would have scratched.im lookin to get some white walls for it possibly too for the time being.and eventually go to 18 or 20s
#25 |
Insert Title Here
I think it sits perfect now, I wouldnt bag it at all
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
