12-24-2009, 05:08 PM | #1 |
Valve Mufflers/Silencers
What's everybody using for air valve dump silencers? I found these. Do they quiet the noise pretty good?
I even thought about running the dump lines, (I have 2, for an Accu-Air manifold), to the exhaust pipes right after the mufflers. If I could weld a 12" or so length of 3/8" tubing to the pipe and attach the air lines to the end to keep the heat from melting them, I think that would keep the noise down pretty good, especially when the truck is running. |
12-28-2009, 01:27 AM | #2 |
67-72 parts collector,…
Re: Valve Mufflers/Silencers
I would give SuicideDoors a call and ask them. I believe they sell these.
Anyone else know? |
12-28-2009, 11:31 AM | #3 |
AIRBAGPARTS.COM
Just use a muffler/silencer. They work great and take all of 2 seconds to install. Personally I have never used the ones you pictured, but have seen them many times. So that leads me to believe that they work. We also sell these different styles.
12-28-2009, 11:50 AM | #4 |
Redefining LowBudget
I'm listening to results
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-28-2009, 12:15 PM | #5 |
i use the ones on the top that avs jason pictured. they quite and you can adjust the dump speed
12-28-2009, 03:36 PM | #6 |
tell us more?? how do you adjust the speed??..I personally want it to stay as fast as my 3/8" line will allow...and quite..I hate the noise it attacks attention..I would rather hear the heads drag than that pissing noise
12-28-2009, 08:26 PM | #7 |
It'd be alot cooler if you did
I'm running these from Grainger. I like them because I can slow them waaaaay down.
To adjust them you just turn the screw on the end of them. http://www.grainger.com/Grainger/items/4ZJ85?Pid=search Last edited by smashingchuck; 12-28-2009 at 08:29 PM. |
12-28-2009, 08:58 PM | #8 |
I'm running the ones in the last pic that AVS JASON posted. They work fine for quieting the sound down ,but they're not adjustable for speed , mine is just as fast with or without them installed.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
