Old 01-24-2003, 09:24 PM   #1
Razorback_Fan
Razorback_Fan's Avatar
Finally got my truck back but........
I'll post some pics of the new paint tomorrow. Ok truck ran fine today went out tonight to start it and you guessed it nothing click click no lights either. The battery charger shows full charge. Any suggestions on where to start?????
Razorback_Fan is offline   Reply With Quote
Old 01-24-2003, 10:15 PM   #2
SCOTI
SCOTI's Avatar
Check cable connections for corrosion. Check your ground & make sure its bolted down tight.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2003, 10:38 PM   #3
Razorback_Fan
did that already
Its like it has a direct short somewhere. I mean I have no lights at all headlight,brake,tail nothing and of course it will not start or even make the infamous click sound. I replaced the starter about 6 mths ago could it be the fuseable link?????
Old 01-24-2003, 10:47 PM   #4
SCOTI
SCOTI's Avatar
Yes, if you dont have lights or anything, start tracing wires from the starter back up the harness. I just got finished last week replacing all the original fusible links on my 74 w/newer 'blade' style plug in fuses & then put new 1 guage cables on & what a difference it made when starting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2003, 11:21 AM   #5
Razorback_Fan
I'll start traceing when it warms up a little. If it is the fuseable link can I eliminate it. What does a fuseable link do?
Old 01-25-2003, 11:56 AM   #6
SCOTI
SCOTI's Avatar
A fusible link shouldn't be removed. If there's a surge or short somewhere in the wiring it is designed to be the fail-safe so the rest of the wiring doesn't melt/burn up.
The F.L.'s on my 74 were down by the starter & hot exhaust. They fell apart when I touched them as I was inspecting the quality of the starter circuit wiring. Since there's alot of heat @ that location, I decided to move them further up in the wiring. This helped in 2 ways: 1) it moved them away from harmful excessive heat; 2) the blade style fuse has the same 'failsafe' ability, but can easily be replaced where they're located on the firewall (and removed for security purposes if so desired).
The ones I used, I picked up @ my local autozone. They are 10-guage wiring & I put 25-amp fuses in them. These particular ones also enclosed the fuse w/a little snap-on style lid to keep out dirt/moisture. I used solderless crimp-on connections w/heatshrink to ensure quality connections. Good luck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2003, 12:54 PM   #7
Razorback_Fan
Fuseable Link
I found the other fuseable link that I bought when I put the starter on. Its a Universal Fuseable Link 14 gauge I got it a O Reilleys. It does not have a place for a fuse so I guess something inside the wire pops. Anywasy should I go and get a 10 gauge????
Old 01-25-2003, 03:08 PM   #8
SCOTI
SCOTI's Avatar
No, you should use whatever gauge wire that was originally used. Typically the smaller wire indicates less current is needed. The ones I used also came in different guage wire selections. The original style F.L.'s were encapsuled in plastic to contain the failure of the wire w/o damage to other surrounding wiring ( I don't know of a way to check them w/o putting voltage to one end & checking it @ the opposite end of the wire). That's the beauty of the newer style links, they can be inspected for failure & repaired w/a new fuse. For wiring of a smaller dia/guage, simply use a lower rated fuse ex: 14ga wire= 10amp fuse; 16-18ga=5 or 7.5amp; 10ga=25amp. Err on the side of caution, & use the smallest rated fuse needed so as to not over-tax the wiring.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2003, 05:51 PM   #9
Razorback_Fan
Got It
It turned out to be the fuseable link connector had backed off enough to short out. Re Spliced it and all is well. Thanks for the help.
