12-25-2009, 01:24 AM | #1 |
A/C heater vent not blowing front dash
I'm new and need some help. I have an 82 gmc 1/2 that I cannot fix, it blows a/c and heat from below under the dash strong, but blows very little in the vents that are in the dash for some reason, does anyone know what it could be.....help....
Thanks AD.... |
12-25-2009, 06:30 AM | #2 |
Re: A/C heater vent not blowing front dash
It's probably the blend door in the heater box under the dash (below the glovebox), or you have arotted or disconnected vacuum line to an actuator that controls the air flow.
12-26-2009, 02:35 AM | #3 |
Thanks for your input
12-26-2009, 08:10 AM | #4 |
78K & 79C Jimmys
hi just above the gas pedal make sure there is a vac line on the (floor to defrost)diaphram,and on the pass side remove the duct work to access and check if this clip is broke door won't work to close vents
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-26-2009, 07:38 PM | #5 |
OutOfMyMind & I'llNeverKnowWhy
I have that same problem and it turned out to be the plastic part broken just like in the pic above. Does anyone know where to buy a replacement part?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
12-27-2009, 12:40 PM | #6 |
They are still available from GM. I bought a whole package of 5 on 12/10/09. The part number is 3018715 and they list for $2.25 each. I just bought the whole package so I have some spares for the other trucks.
Hope this helps. |
12-28-2009, 02:03 PM | #7 |
Thanks for the info.....
AD...... |
12-28-2009, 08:59 PM | #8 |
Thanks for the part #
01-04-2010, 08:23 PM | #9 |
Hi guys im new and i ran across this post and im having a similar problem. My heater/ac blows buts it comes out in both places defrost and front vents at the same time. I replaced that clip shown in the picture above but it seems like i have no vacuum. I have a 1987 silverado efi throttle body. Can anyone tell me exactly where it gets its vacuum from.
01-05-2010, 03:31 PM | #10 | |
Should I be looking at the same thing? Any place I can look that explains the mechanics of how the HVAC system works?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
07-18-2012, 11:47 AM | #11 |
Hey motornut can u move that bundle of wires and get a pic of that top part? The person who had my truck before me decided to take the springs and that rod with the screw end off. I guess they did not pay attention to how they took it apart cuz it was just laying on top.
07-18-2012, 12:03 PM | #12 |
Getting Old; Going Broke
Hang on, he has to get the runway cleared so he can reach 88mph!
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
07-18-2012, 01:26 PM | #13 |
78K & 79C Jimmys
a little from the side?
07-18-2012, 02:32 PM | #14 |
Little more left??? Other end of that rod plz
07-19-2012, 09:57 AM | #15 |
78K & 79C Jimmys
sorry didn't get any that way
07-19-2012, 10:49 AM | #16 |
Darn.....thanks anyway
07-19-2012, 10:50 AM | #17 |
any idea where to get a look at it???
07-19-2012, 11:03 AM | #18 |
78K & 79C Jimmys
no sorry the jimmys don't have AC
and that truck is about an hour away going for scrap soon....
07-19-2012, 11:07 AM | #19 |
ok thanks
11-29-2014, 06:53 AM | #20 |
Rottenwood Garage Member
I had the same issue. Mine was the small hard plastic vacuum line coming through the firewall next to the heater box in the engine bay.. It had been broken and not repaired. No vacuum was getting to the control unit to make the switch happen.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
11-29-2014, 08:36 AM | #21 |
Figured it out. The vacuum line was hooked up to the wrong place. It was on the carburator where it was not getting constant vacuum. Moved it to manifold and it works great now. Thanks for the help. Vacuum problems are a pain in the rear.
