12-25-2009, 11:22 AM | #1 |
Quadrajet question
Merry Christmas to all.
I am wanting to replace carb on my Jeep CJ-5 304ci ( I know not Truck) and have had Great luck with My Q-Jet on my 70 GMC 4x4. It was rebuilt by Cliff Ruggles. I do not want to wait that long for another. Anyhow which Q-Jet would be the best to get? I want an electric choke. Does it matter what year carb I use, and which would work best(Year wise). The only reason I ask here is there is more knowledge here than anywhere else. Thanks and Happy Holiday's Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
12-25-2009, 11:29 AM | #2 |
Re: Quadrajet question
I have had great luck buying my Q-jet from National Carburetors. Use ND2465 $199.95 with electric choke.
http://www.nationalcarburetors.com/l...partnum=nd2465
Mine is chopped, has a clutch, and a big block. |
12-25-2009, 03:21 PM | #3 |
The Jeep probably uses a square bore carb. A Q-jet is spread bore & won't work on that manifold without an adapter which isn't very practical. It's best to fix the carb that is on it. The Edelbrock performer is a good replacement.
12-25-2009, 05:50 PM | #4 |
I have Edelbrock on it now and seems to have dead spot wher it bogs. It also has a starting problem after it sits for a while. I have tried just about everything I can think of to remedy with no luck. I have even tried to take it to a repitable Mechanic and he told me to get a Holley or a Q-Jet and he would fix it.
I have the original Q-Jet on my 70 GMC 4x4 rebuilt and it works near flawless. I have considered buying a Summit Carb but did some research and have found some Holley's don't do well on 4x4's, and Q-jet's are suppose to work well on 4x4's. I just thought if I tried a different route I may have better luck. Thnaks for any help Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson Last edited by Husker; 12-25-2009 at 05:59 PM. |
12-25-2009, 06:27 PM | #5 |
If it's a 4bbl manifold I would put a Motorcraft 4300 on it. 2bbl 2150.
http://cgi.ebay.com/ebaymotors/Vinta...item20aea0a51f |
12-25-2009, 08:30 PM | #6 |
My 1971 4x4 has a new Edelbrock 1406 It SUCKS when off road at the slightest angle it bogs and pukes. I did the research and most wheelers go with Q-Jets. Lots of opions on them in the Summit Catalog. Anyone want to trade a nice rebuilt Q-Jet for the 1406 let me know.
Brew |
12-25-2009, 08:54 PM | #7 |
airdale94 I am a Chevy, Jeep guy, My Jeep had the Edelbrock on it when I bought it. Don't know much about Ford Is this a Good Carb.
I know it may have had a Motorcraft as stock carburetor. It had the Motorcraft crappy Ignition now has HEI. Anyhow is this a GOOD choice? The Edelbrock I have now seems to OK at times but others not so Good. Has a dead spot that I can't seem to find. Thanks for all the help Ron
12-26-2009, 10:12 AM | #8 |
Get the numbers off the Q-jet (drivers side) and call National Carb and get a carb just like the one on your chevy.
http://www.florida4x4.com/tech/quadrajet/index.php I have included a good Q-jet link that has everything. You can even get an old core with the same numbers off ebay and send to National Carb for rebuild. Cores cost $40
12-26-2009, 10:31 AM | #9 | |
Middle-aged Curmudgeon
If you plan to find and build it yourself, I would suggest Googling any and all Q-jet information you can find by Lars Grimsrud. I found his technical papers to be extremely beneficial when I was building mine. Even if you don't plan on building your carb, the information in his papers make for some very interesting reading and you'll be much more informed when looking for one or consulting with the person who is actually tuning it.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
12-26-2009, 10:42 AM | #10 |
I have an old quad on mine that my dad modded to suit my lopey cam and it is great, no choke but it doent take more than a minute to idle on its own, he has a book he bought online on how to makem work, my dad put one on a ram with a 360 it really improved the drivability of it too [cam,headers,etc] it required an adapt but who cares it got better milage and ran strong
12-27-2009, 04:46 AM | #11 |
70 Chevrolet=Obsession
Summit has exact replacement Q-jets with electric choke.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
12-27-2009, 01:25 PM | #12 | |
12-27-2009, 03:22 PM | #13 | |
I always figured the pre-emission carbs would be more desirable. What makes the mid-late 70's carbs good? I have one from 1979 laying in the shop and have yet to do anything with it.
-Tony Money is no object... once it's in your wife's hands. 1972 GMC Sierra 1977 Ford LTD II 2000 Pontiac Grand Prix (wife's ride) |
12-27-2009, 06:15 PM | #14 |
Old Skool Club
The Q-Jets made for emissions controls became less user-friendly. The early ones had idle air adjustment screws that were later made inaccessible. If you see a Q-Jet with what looks like something that was broken off of the front of the carb, that will be one. The idle air screws on those were different, too. Some were known as Mod-Quads and later ones had electric accelerator pumps and they will have an electrical connector that has to be attached to something to make it work.
First Q-Jets came out in '66, as I remember. But, for the performance muscle cars of that day and time, like the SS396 Chevelles....GM used Holley's.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-27-2009, 07:00 PM | #15 |
The late 70's early 80's had electric chokes or the round choke that can be converted to electric. They can be used on practically any manifold. The easrlier ones had a divorced choke heater of several different designs. They had to be used with a corresponding manifold. The 70's -80's had some improvements like more screws holding them together to prevent warpage. You don't want the mid 80's that had the elctronic feedback. They will not work right without computers.
12-28-2009, 03:02 PM | #16 | |
http://www.tekatlarge.com/Automobile...0%20Carb1.html http://www.therangerstation.com/tech..._2150_carb.pdf |
12-29-2009, 08:56 PM | #17 |
Thanks everyone for the Help alot of good info.
Ron
