View Poll Results: Which way should I go?
4" lift & 35" tires 8 47.06%
2wd conversion and lower it 4 23.53%
2wd conversion, lower it & full top conversion 5 29.41%
Other (describe any other ideas) 0 0%
Voters: 17. You may not vote on this poll
Old 12-25-2009, 04:12 PM   #1
Conundrum
Conundrum's Avatar
Should I?
So I find myself in a bit of a conundrum....
I have a 79 chevy k5 blazer, 4wd stock height on 33s. The body is a little rough but I have all the sheet metal I need to fix that problem. My wife has a hard time getting in and out of it as it is being she is only 5'3". If I leave it 4wd drive I want to do a 4" lift with some 35s, but that will make it that much harder for her to get in and out.
So my conundrum is do I lift it or do a 2wd conversion and lower it? Either way there will be compromises and sacrifices to make, 4wd lift = harder for the wife to get in/out of but i'll gain ground clearance for our random winter weather like we got lastnight here in southeast KS. 2wd and dropped = easier for her to get in/out of but we sacrifice that winter driveability. Also I can pick up a 74 blazer parts truck for a full convertible top conversion for $125.
I'd like to know your opinions on this.....
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 12-25-2009, 10:34 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Should I?
You dont mention it being a vehicle you NEED to have running so I would do a 2wd swap. 4wd K5's are very easy to come by so if you change your mind you wouldnt have any problem trading or selling it to buy a 4wd. Thats my opinion, at least after about 8 hours of holiday drinking
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-25-2009, 10:37 PM   #3
OARNGESI
OARNGESI's Avatar
Re: Should I?
Go full convt 2wd
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-25-2009, 11:57 PM   #4
USSkoval
Re: Should I?
Have any current pics of said Blazer? It would help me determine my vote (and likely other peoples').
USSkoval is offline   Reply With Quote
Old 12-26-2009, 12:57 AM   #5
Conundrum
Conundrum's Avatar
Re: Should I?
I have a 76 Blazer chassis that I could do the 2wd conversion on and then swap the body over and keep any down time to a minimum, that is if the 76 chassis will interchange with the 79 I think it's the same.
Here is the link to a thread I have some pics of my Blazer on,
http://67-72chevytrucks.com/vboard/s...d.php?t=364589
I'm definitely leaning towards the full convert, I really like the way they look.
Old 12-26-2009, 07:59 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Should I?
I think you know what I am going to say...
tvblazer78 is offline   Reply With Quote
Old 12-28-2009, 12:41 AM   #7
USSkoval
Re: Should I?
OK, yeah, full vert and 2wd... it just makes sense.
It's not a real clean original truck, so no worries there. The front clip needs replaced, so while it's off, you might as well go 2wd and fix the rust around the windsheild frame. Rather than fixing the rust, it would just make sense to replace the windsheild frame with that of a full vert. The pieces of the puzzle all fit together
Also, the '76 frame would be different, due to the lack of a rear foot well.
Old 12-29-2009, 11:47 AM   #8
Conundrum
Conundrum's Avatar
Re: Should I?
Well I hit a pretty good delay yesterday or maybe it's a good motivator.
My transmission went out on me, I had been dealing with a bad battery for a little while and I got a new one saturday and then the trans goes out. Luckily my dad has another 4wd th350 that he just picked up a couple weeks ago, so at least I don't have to try and find one.
Old 12-29-2009, 06:49 PM   #9
justpball
justpball's Avatar
Re: Should I?
do the 2wd frame and keep the 4x4 frame and swap them out each year so you have a 4x4 one year and low rider the next year...LOL
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-29-2009, 07:59 PM   #10
Conundrum
Conundrum's Avatar
Re: Should I?
Old 12-29-2009, 10:31 PM   #11
justpball
justpball's Avatar
Re: Should I?
I thought you would like that....
87 Crew SWB
Build for the crew
90 burb 2wd
