12-25-2009, 08:28 PM | #1 |
Edelbrock 2101 intake manifolds $120.00
Description: Performer (non-EGR)
Chevrolet 262-400 Small-Block V8 PERFORMER - '86 & EARLIER (idle-5500 rpm) Designed for street 1955-86 262-400 c.i.d. small-block Chevys. #2101 is stock replacement/street legal part for 302, 327 and 350 V8s with OEM 4-bbl. or Edelbrock #1400 carb Features: Performers accept late-model choke, waterneck, air-conditioning, alternator and H.E.I. Has provisions to add oil fill tube. Not for 1987 and later cast iron or Chevy Bowtie heads. Will fit 1987 and later stock aluminum heads. Other: Installation Notes: Use adapter #8035 for clamp-on EGR valve. With carb #1400 & #3701, EGR spacer #1476 is required. #1476 is required with #3701 on centerbolt heads with 1986 & earlier bolt pattern. Choke plate #8901 included. Recommended intake gasket: Edelbrock #7201. Manifold height: A-3.50", B- 4.60" see A/B Measurements. Port exit dimensions: 1.14" x 1.88".Carburetor Recommendations: OEM 4-bbl., use choke rod #9171, bracket #8031 or #8036 for 1972-78 Edelbrock Thunder Series AVS or Performer Series carb, 500-650 cfm (see Carbs & Accessories), use bracket #8031 or #8036 for 1972-78 SHIPS TOMORROW LIMITED QUANTITIES |
