Old 12-25-2009, 09:15 PM   #1
stevewhitmore
stevewhitmore's Avatar
Rear Lowering Questions
Hey Guys,
If I get new 2" lowering coil springs for the rear on my 69 SB to level it out
1. Do I also need to get lowering shocks?
2. Will it interfere with my new exhaust or anything else?
Stevew
stevewhitmore is offline   Reply With Quote
Old 12-25-2009, 09:55 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Rear Lowering Questions
1) I would say no.
2) Only you know how much room is between the rear axle and your new exhaust.
Get out a tape measure and see if you have room to drop it down 2 inches.
You shouldn't have problems with exhaust clearances being tight until you drop them around 6",...
but I don't know how your exhaust was run.
Old 12-27-2009, 04:57 AM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
1.) 2" is pretty mild so you shouldn't have to do anything but install springs.
2.) Like lolife99 said, we can't answer that for sure but I'm guessing you won't have a problem. Throw a couple of hundred pounds in back, crawl underneath and check it out.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-27-2009, 08:35 AM   #4
big_al_71
big_al_71's Avatar
I went with six inch rear springs and had zero issues as far as the exahust touching anywhere.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-27-2009, 08:42 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I put 2" blocks on the back of the White '67 and didn't have any issues with the shocks.
LockDoc
Leon
Old 12-27-2009, 08:32 PM   #6
chevguy7
chevguy7's Avatar
You will not have to worry with a 2 inch drop. From what I have heard you do not have to relocate your shocks until you get to 5 inches.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
