12-25-2009, 10:20 PM | #1 |
33x12.50 a/ts
would i be able to fit 33x12.50 tires on my stock k10 with out any trimming. or is the biggest i can go a 32 inch tire ?
heres a pic of my truck for reference for the height. there tires there are 31x10.50,well the rear tire the front tire is a spare. but the rear tire stands 29 inchees tall because its so worn down and old Last edited by 8swbk10; 12-25-2009 at 10:22 PM. |
12-25-2009, 10:21 PM | #2 |
Watchin the rust grow
Re: 33x12.50 a/ts
Some people say you can, some people say you cannot.
I've heard it'll fit with no rubbing, it'll fit with rubbing when you flex, and that it'll fit but rub at full turn. I've heard that they barely fit and rub with the slightest bump. I'm interested to see the other replies.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
12-25-2009, 10:28 PM | #3 |
Re: 33x12.50 a/ts
it will also depend on the tire brand, rim width and backspacing of the rim...
I'm guessing it won't fit easily, that's a guess though,,,
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-25-2009, 10:29 PM | #4 |
Re: 33x12.50 a/ts
ive heard the same thing. i dont think il be using it for much offroading where itll be flexing,just trying to make it into a beach truck
12-25-2009, 10:31 PM | #5 |
Re: 33x12.50 a/ts
msgross idk what brand il be getting im gonna find used tires for now on a 15x10 rim and once i get money saved up(since im only 16) il be buying new 33 inch bf goodrich all terrains
12-26-2009, 10:03 AM | #6 |
Re: 33x12.50 a/ts
They won't fit on 10" wheels. I had an old 75 1/2, put 33's on it and it rubbed when turning/flexing. Might one to put an add a leaf or zero rate for a small lift, that will help.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
12-26-2009, 12:26 PM | #7 |
Re: 33x12.50 a/ts
Your truck seems to be a little taller than most. Mine was similar with diesel springs & it cleared 32's on factory 8" wheels.
Wider wheels push them outwards & will definitely contact the fenders (likely even with 32's) when you turn. 33 x 12.50's on 8" wheels will tend to wear the centers out as it pulls the sidewalls in but will likely clear the fenders except when turned sharp. |
12-26-2009, 02:13 PM | #8 |
Re: 33x12.50 a/ts
i had to trim the lower fender lips on the front when i did mine.
12-26-2009, 03:56 PM | #9 |
Re: 33x12.50 a/ts
thanks for the help guys,im most likely going to go with 32's. and after i do a small lift and 32's wear out il get 33's...i was also thinking of re-arching the springs just wondering if the arch will last awhile or not
12-27-2009, 02:43 AM | #10 |
Re: 33x12.50 a/ts
Yo! Here's mine with no real lift, just flatbed axles/springs, and 33" 285/70/17s:
They've got 9 full inches of tread and are about 12" in total width. No problems. The tread comes within about 2" of the rear of the front wheel well on turning, but has never rubbed. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! Last edited by asphaltburner; 12-27-2009 at 02:44 AM. |
12-27-2009, 04:22 AM | #11 | |
Re: 33x12.50 a/ts
and on my stock 1979 k10 with negative worn leafs it still fit 33's on a 8" rim no problems( my dad and i drove the truck a while) except when it had a load in it and hit a hard bump. |
12-27-2009, 07:25 PM | #12 |
Re: 33x12.50 a/ts
to asphaltburner my truck sits about the same,so i think i can fit 33s.
12-27-2009, 08:22 PM | #13 |
Re: 33x12.50 a/ts
I have 33/12.50s on 8" wheels on my stock 79 K5.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
12-27-2009, 10:10 PM | #14 |
Re: 33x12.50 a/ts
Yo! dmartin1!
Geeze, thanks! Built it from scratch myself. Got aways to go, but I'm driving it! Take a look at it on it's belly with the cows where I found it: http://67-72chevytrucks.com/vboard/s...d.php?t=301610 Thanks again! Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
12-27-2009, 10:23 PM | #15 |
Re: 33x12.50 a/ts
My 82,4x4 longbed Chevy came with Firestone P-235-15's.Before it was a year old,I put Kelly/Springfield 12.50x33x15's on it.
Since it's had the BFG's you want,(on it now),Goodyears and another brand I can't remember. Over 300,000 miles and the only time it ever rubbed was on the beach on a hard left or right turn. And I've got a 454 and winch.(added an extra spring on the front for the extra weight) Mike. |
