01-24-2003, 11:44 PM | #1 |
Pronounced "Pew-al-up"
Front Disc Brakes
I know this has been discussed, but I am wondering
what Front Disc brakes will work with my six lug 1/2 ton chevy truck. I dont want to pay the new conversion prices, plus it takes away from the fun of of hiking thru the mud at the local salvage yards. What should I be looking for that will bolt up without too much alteration?? I also want to drop my truck another 3", so I'll be buying drop spindles. I have a lot of money into my wheels, so changing to a 5 lug is not an option right now. Any help would be cool...
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
01-25-2003, 12:27 AM | #2 |
Careful, they attack...
I do't think there is any bolt up jumk yard parts for you if you don't want to go 5 lug. You only option that I know of would be to get a kit for 6 lug disc. But since you don't want that you in a bad spot. Plus I don't think they make drop spindles for six lug drum brake trucks. That is why I am going 5 lug. But with all the money you have in wheels, I would stick with what you have and get some springs or maybe a set of dropped lower control arms. LMC has the arms. And any board vendor has the springs. Good luck.
jmanz69 |
01-25-2003, 12:50 AM | #3 |
entire front suspension assembly from a 71-87 truck with pair of aftermarket 6 lug rotors will do it
01-25-2003, 01:02 AM | #4 |
Really? Any front end setup 71-87??
That shouldnt be too hard to find? Thanks
01-25-2003, 01:44 AM | #5 |
its all about the +6 inches
Somewhere in the 73 - 87 they went to metric, you'll want to stay with the older ones if you can...keep it all fractional to make i easy. Also, if you get a 73 and up, parts are a bit cheaper from what I understand.
01-25-2003, 08:51 AM | #6 |
I didn't realize you could get just the rotors in 6 lug. I thought you had to get the whole kit. Good news for people that like the 6 lug, but want to be able to stop.
01-25-2003, 09:00 AM | #7 |
82 After is Metric
I installed a 81 front end on my 70cst and the whole front end cost $150. It's a direct fit. Plus you get a better steering box which is a Quick Ratio Box when compared to the 67-72 truck. As mentioned I believe 82 and after were metric. Also a 71-72 rear hubs will slide right into the the 70 Chevy/GMC truck w/o any mods. (67-69 will not workk as the DIMS. are different) That's what I did for my 70cst. The rear hubs cost me $75. You still need to rebuild the front end but it is the best of both worlds. Now I have 5 lug front and back.
Regards 70cst |
01-25-2003, 10:41 AM | #8 |
If you go to get the front parts off a 73 up truck and wish to use the 6 lug rotors that are available for use on these trucks spindles to convert them to 6 lug you will need to be sure that you get your donor parts from a truck with 1 1/4"thick front rotors and not the ones that came with 1" thick as they used 2 styles and the 6 lug rotor can only be used on trucks that originally used 1 1/4" thick 5 lug rotors originally. Otherwise the 71-87 truck, and 71-91 Blazer & Jimmy 2wd drive are all excellant donors.
GMCPaul |
01-26-2003, 01:01 AM | #9 |
Good tip Paul, I was unaware of that.
01-26-2003, 01:43 AM | #10 |
Thats why I like this board, GMCPaul, and 70CST just saved me a lot of frustration!!!
Thanks!!!!
01-26-2003, 07:11 AM | #11 |
Another FYI.In 84 they changed the hole and stud size on the idler arm.They are otherwise the same as the older ones but cost twice as much.
01-26-2003, 09:31 PM | #12 | |
yes keep forgetting to point that out, the 1.25" rotors are under the heavier duty 1/2 tons like the Big 10 and GMC Heavy Half models, any truck with heavier than std GVW rating, HD suspensions, |
