Old 12-25-2009, 11:49 PM   #1
im tha best
im tha best's Avatar
For all you sixbanger guys out there
I was wondering which transmissions you guys run because im debating getting a new tranny or just getting my stock one rebuilt...Im not sure which would be the cheapiest route to go, I still have to see what it would cost to rebuild the one I have now or just get a new one, to make my final choice on how i should go about this. The reason behind this is that there is a horrible whinning noise when I take off in first gear and its sucking all of what little torque I have away. thanks for the help guys!
68 Chevy C10 long box
im tha best is offline   Reply With Quote
Old 12-25-2009, 11:58 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: For all you sixbanger guys out there
Currently and from the factory I'm running the stock 2 spd. powerglide.
I know a 200R4 would be nice behind any 6 cylinder, or at least that would be my choice, but the cost will be higher.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-26-2009, 12:04 AM   #3
im tha best
i could be able to get ahold of a guy that i know that has a two speed powerglide with a torque converter but I would really like to find something thats quick with good gas milage, im not sure if i'll be able to find something like that, but i would really like to try.
Old 12-26-2009, 12:15 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
200r4 will offer you overdrive which will help with MPG.
With my 250 backed by the P/G I can ran from 12-21 mpg depending how I drive it, which I consider fair since the truck is 40 years old.
-Nate
Old 12-26-2009, 12:21 AM   #5
im tha best
true true. i actually dont know how much i get per gallon because 1) my speedo doesnt work so i cant tell how many miles i've gone anndd 2) my gas gauge doesnt work so even if my speedo did work, i wouldnt be able to tell how much gas i've used haha.
on another note, does a 2 spd. gilde bolt right up to the bell housing and would i need to get a longer/shorter driveshaft in order for it to work properly?
