12-26-2009, 07:34 AM | #1 |
first crew cab
hay guys im new hear iv got a 72 3/4 ton 4x4 but im wanting to build a bagged crew cab next any sugestions like what fram i could use im lookn at use a 5.9 cummins as the power plant any help will be really helpfull
12-27-2009, 12:22 AM | #2 |
its all about the +6 inches
Re: first crew cab
welcome to the board sea wolf.
What are you going to use for a crew cab? One of the ones converted back in the day and sold through the GM dealers, or are you looking to fab one up? |
12-27-2009, 01:04 AM | #3 |
Re: first crew cab
probable ganna fab one using two cabs it would be a lot of work but possible
12-27-2009, 11:30 PM | #4 |
Suburban Hick
Re: first crew cab
I would use a 3/4 or one ton frame and the njust lengthen it. If you look at the frames of a 1/2 ton and 3/4 ton there is significant difference under the cab area on how thick the rails are. Then i would brace it of course. 5.9 cummins is a great idea for a powerplant. Dieselwrencher swears by those things. Also there was a member on here up in oregon who had a crewcab for sale a while back, with suicide doors if i remember correctly.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
12-28-2009, 12:17 AM | #5 |
Re: first crew cab
Lots of work and not sure I would want to go back down that road. I have a decent crew cab truck here in Vacaville you could check out. There are a couple of crew cab lurking on the board here that look really good.
12-28-2009, 12:23 AM | #6 |
Re: first crew cab
1/2 ton and 3/4 ton frames are pretty much the same. I would start with a one ton.
12-28-2009, 12:27 AM | #7 |
Re: first crew cab
I would agree as my truck is on a 79 1 ton frame and the frame is huge.
12-28-2009, 07:29 PM | #8 |
Suburban Hick
Re: first crew cab
There is siginificant difference between 1/2 and 3/4 ton frames. Yes i would recommend a 1 ton frame but top to bottom on a 1/2 ton frame under the cab is about 6 inches and on a 3/4ton frame its about 8 inches and they are usually a little thicker.
12-28-2009, 09:35 PM | #9 |
Re: first crew cab
I like the mirror set up on that truck.. I been wrestling with what to do for quite some time. I welded up all the holes in my doors when it was painted. I was thinking of taking newer flip up dodge mirrors and using the corner piece when you install one piece windows to mount them on.. BUT, i have yet to put my doors together because I had not decided to go that route for sure. (one of those things I wish I would have figured out before paint) However, since I have all the parts to rebuild my window glass with all new rubber and felt and I like the looks of this....... Maybe I found my answer!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
12-28-2009, 10:34 PM | #10 |
Re: first crew cab
No diference in 1/2 T and 3/4T frame other than some bracing and suspension.....Now the difference between a those two and a 1 T frame is pretty significant.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-29-2009, 03:02 AM | #11 |
Re: first crew cab
i was thinkn about using a four door frame like some of you had said. i dont have a problem fabin up the cab but were would i cut the cabs im wanting to try and run pillerless doors iv got some ideas on that. like suicide rear doors and iv'e heard that there are diffrences in chevy and gmc frames is that true?
12-29-2009, 05:10 PM | #12 | |
Re: first crew cab
A longhorn is built on a one ton frame, so it falls under the one ton specs, with a taller, and thicker metal used for the frame rails. All this is 67 - 72 specific... anything built after that I can not comment on. |
12-29-2009, 05:48 PM | #13 |
Re: first crew cab
No, it's not true. Frames will differ in the rear if they have coil springs or leaf springs, but Chevy and GMC could have either suspension.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-29-2009, 06:46 PM | #14 |
Currently Blazerless
Re: first crew cab
Thats the nicest crewcab I have seen done, Beautiful!! I didnt realize you were that far along with it..any more pics of it??
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-29-2009, 11:51 PM | #15 |
gets board easy.......
Re: first crew cab
have fun, seems to be a popular build these days
12-30-2009, 12:52 AM | #16 |
Restoring a 68 SWB
Re: first crew cab
Very nice! Haven't seen it since you got it painted.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
12-30-2009, 01:17 AM | #17 |
Re: first crew cab
Thanks for the kind words, I will be posting some more pictures in the next couple of days.
