Old 12-26-2009, 01:15 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
72' 2.5" & 4" drop
Looking to do a 2.5" spindle and 4" spring drop on my 72' swb chassis . I looked at ECE for the parts as they seem too have a good reputation on here . Will i need anything oter that the 2.5" spindles and the 4" springs ? Probably get the rear shock locators also . Do i need an adjustable track bar ? Just trying to order everything i need in one shot .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-26-2009, 02:04 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 72' 2.5" & 4" drop
ECE is top notch!!!
For the front, assuming all your other parts are in good shape, spindles is all you need.
For the rear, you can get away with just springs at 4" but shock relocators and adjustable track bar will make it ride better and allow you to center the tires. If you are going to do those two items, you might pony up for new U bolts, since getting the old ones off can be a pain and they are almost 40 years old.
Good luck and post up pics when you do it.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
