Old 12-27-2009, 01:29 PM   #1
Neal Molder
The Black Pearl
P.O.R Question
I bought some P.O.R to do my new front end parts. Upper and lower a arm shafts. tie rods inner and outer. pitman arm etc.. Just wondering if anyone has used this stuff on new metal. I planned on using metal ready ,then p.o.r then chassis black as a top coat as recommended. just wondering if this is a good plan or not. The rest of my chassis is powdercoated black. Does anybody have experience with P.O.R and New Parts ?
Neal Molder is offline   Reply With Quote
Old 12-27-2009, 01:55 PM   #2
cdowns
cdowns's Avatar
Re: P.O.R Question
i've always blasted new parts to give some texture for the POR15 to adhere to as it doesnt stick so good to smooth new metal
Old 12-27-2009, 02:44 PM   #3
Neal Molder
The Black Pearl
Re: P.O.R Question
Thats going to be a pain, since i aready have my a arm shafts intalled on the freshly powdercoated a arms. Also i would have to take all parts to my sandblaster guy. And i'm also thinking my threads on my tie rods would look weird if i left them bare, but if i paint them with p.o.r i'll never be able to adjust them. I'm starting to realize why the majority of the guys on this site just leave them bare metal. Maybe i'll be better off just getting some good automotive paint in a spray bomb and spray them black to match the black powdercoat. Maybe P.o.r would be best in a different application? What do you think?
I know i'm getting a little anal but i do not want to have to redo any parts especially all the new parts once finished. A good spray paint properly applied might be good enough. especially because this truck will not be a driver. It will be a weekend warrior and trailor princess.
Old 12-27-2009, 09:17 PM   #4
Neal Molder
The Black Pearl
Re: P.O.R Question
Has anyone used P.O.R on new steel?
Old 12-27-2009, 09:49 PM   #5
dfwright
dfwright's Avatar
Re: P.O.R Question
I've also been blasting any parts before applying POR15, but the instruction sheet does give details on recommended procedure for new/smooth metal.
I would give them a call, the number is on the por15.com website, and ask them how best to handle what you want to do.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-27-2009, 11:19 PM   #6
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: P.O.R Question
I painted a new set of springs with por 15 and it didn't turn out so hot. On the other hand everything that was blasted turned out great. I did the entire frame, axle, a-arms, and everything else in por 15 and love the way it turned out.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 12-28-2009, 01:23 AM   #7
Smallz72project
Smallz72project's Avatar
Re: P.O.R Question
This is just a suggestion. On the inner and outer tierod ends...I wouldnt go through that much trouble and cost to paint them with chassi black and por...stuff isnt cheap plus those are a wear item so you will end up replacing them eventually. If you do so feel inclined to go the extra mile I would just tape off the threads and then paint them however you choose. On the thread side..get yourself a bottle of anti-seize and be liberal with it on the threads....your alignment guy will thank you. This naturally coming from a certified alignment tech good luck and keep on truckin
PS. from what I have read in numorous threads and their own website, POR15 will not stick to bare metal, its made to adhere to rust. So if you just simply coat it...it will go on but will peel off shortly after however they do offer what you stated metal ready allow it to work.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 12-28-2009, 02:20 PM   #8
crakarjax
crakarjax's Avatar
Re: P.O.R Question
Just use epoxy primer on clean metal, I use SPI and it works great.
crakarjax is offline   Reply With Quote
Old 12-28-2009, 02:30 PM   #9
mrh33916
Project '67 454
mrh33916's Avatar
Re: P.O.R Question
If you go with a rattle can Rustoleum gloss black enamel matches gloss black POR-15 very well.
mrh33916 is offline   Reply With Quote
Old 12-28-2009, 11:03 PM   #10
Neal Molder
The Black Pearl
Re: P.O.R Question
Thanks for all who replied. I decided to go with some black gloss engine paint i had kickin around. I couldn't bare the thought of redoing if the p.o.r didn't stick.
What is epoxy primer? Is that just ordinary primer before you paint.
Old 12-30-2009, 11:32 PM   #11
crakarjax
crakarjax's Avatar
Re: P.O.R Question
Epoxy primer/sealer is a non-porous finish that is typically recommended as the first basecoat over bare steel.
http://southernpolyurethanes.com/Tec...y%20Primer.htm
Epoxy primers remove the need for acid/etch primers.
http://www.hotrodders.com/forum/solv...an-143345.html
They even sell it in rattle cans now! I have had epoxy primer on my chevelle fenders for a year now in the elements, and it's going strong. Won't rust through because it's non-porous, and it won't degrade rapidly in UV like POR. IMO it should be the first coat on any metal surface.
