12-27-2009, 01:32 PM | #1 |
Heater Fan Question
I do not know if this is the way it is supposed to be or not so I will ask the experts. When I am sitting there and the heater and fan is on, nothing blows out . When I am cruising down the highway it is blowing out full force, so the speed at which I am driving determines the force of the heat. Is this supposed to be or is the fan supposed to run continuous like vehicles nowadays? If the fan is supposed to run continuously where should I look to get it going? This is my first classic vehicle so I am still learning. Thanks in advance for all of your expert comments (and I do consider you all experts!)
12-27-2009, 02:00 PM | #2 |
Has more rust than truck...
Re: Heater Fan Question
Your fan isn't working at all. When you are going down the road air is blowing in through the cowl panel through the heater core. I'd start checking for power (with fan turned on and ignition on run) at the blower motor then the switch on the heater control.
12-27-2009, 02:11 PM | #3 | |
69 Chevy 4x4 383 Power |
12-27-2009, 02:21 PM | #4 |
I've got to go through the same process today. HaysonJ pretty well nailed it.
One of my problems is that a rodent used my heater as a nest/storage compartment at some time in the past and I need to take the shopvac to that. Then it is trace down the electrical issue. It's probably easier to track the electrical trail back from the blower motor but you do want to make sure that the fuse is good first. I know my switch is bad and have it jumped but right now but there are other issues that I have to figure out today on it too. |
12-27-2009, 03:42 PM | #5 |
Hollister Road Co.
I just went through this yesterday. Mine was packed with leaves and something resembling dirt. The mouse had packed the heater tight and nawed on the plastic wheel as well.
12-29-2009, 01:25 PM | #6 |
Thanks guys I will let you all know when I get back from vacation and have a chance to try it out. You guys are awesome!
12-29-2009, 04:58 PM | #7 |
The 2 trucks I have owned of this vintage both had grounding problems. So as stated above, running a jumper should tell you where your problem is.. If it's a non-AC system, they are SUPER easy to work on once you get in there and see how the barn doors work, etc... So troubleshooting it should only take a partial day and a 12 pack...
