Old 12-27-2009, 05:35 PM   #1
resto_rookie
resto_rookie's Avatar
Steering upgrade?
Starting with a bare frame on my first project and looking for a good handling ride. Any suggestions on a steering setup would be appreciated. Thanks
resto_rookie is offline   Reply With Quote
Old 12-27-2009, 05:55 PM   #2
hchad18
hchad18's Avatar
Re: Steering upgrade?
73-87 gearbox would be an upgrade. Less turns lock to lock I think.
hchad18 is offline   Reply With Quote
Old 12-27-2009, 06:22 PM   #3
resto_rookie
Is that a direct bolt-on upgrade or will I need to change anything else?
Old 12-27-2009, 08:29 PM   #4
adpostel
New Member
Would you consider that an upgrade? I have a 73-87 gearbox on my truck and I find it extremely difficult getting around in a parking lot.....
Just wondering.......Thanks
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 12-27-2009, 09:27 PM   #5
Mondo
Mondo's Avatar
If I was doing a frame off, and had the budget, I'd go the rack & pinion route. But it requires new crossmember etc..$$$
http://porterbuiltstreetrods.com/site/
I went thru 4 steering boxes... leaks, slop, quick ratio then variable ratio. Variable ratio is definately the best; ratio gets quicker the more you turn, great for freeway & parking lot.
Don't go for a NAPA type rebuilt or your likely to get slop back in your steering after a few months (I did).
I highly recommend these guys. Tell them what you have and what you want
http://www.redheadsteeringgears.com/
PS - since your doing a frame up you might consider a new pump too (I assume you want power steering).
Mondo is offline   Reply With Quote
Old 12-27-2009, 09:45 PM   #6
resto_rookie
Thanks for the links. I had wondered about the rack and pinion but don't see that fitting into the budget especially since the rest of the suspension has already been purchased.
Old 12-28-2009, 12:57 PM   #7
turp mcspray
turp mcspray's Avatar
I believe there are two different ratios available on the steering boxes. The quicker ratio is like 3.5 turns lock to lock, and the standard ratio is like 5 or so if I remember correctly. When searching for a used box, count the turns and compare to what you have now. I'm sure there is probably a thread with this info.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-28-2009, 04:53 PM   #8
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
The only note of caution that I will throw out is ----
Do not go to the quikest box you can buy - unless you upgrade all the suspension to get the truck to lay flat in a curve - these trucks have are top heavy - if the box is to quick and you are not a rally road driver you can lose control in the blink of an eye and find yourself upside down
Get a new box, new pump and lines it will all be worth the $
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
