Old 12-27-2009, 05:38 PM   #1
chipflyer
chipflyer's Avatar
For those looking for correct cruise
Not mine but here is a very nice 71-72 dealer installed cruise control setup.
Cruise control
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-27-2009, 06:20 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: For those looking for correct cruise
hey Jeff, did you happen to stumble across that bracket yet? Like I said no rush, and I understand if you haven't looked as it's pretty cold around here. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-27-2009, 10:15 PM   #3
chipflyer
chipflyer's Avatar
This is what I have Trevor, if its what you're after you can have it.
Jeff
Old 12-27-2009, 10:21 PM   #4
72 Super
72 Super's Avatar
Was cruise control available in 72 from the factory? or were they all dealer installed units? If it was available would this be the exact same set up?
Thanks,Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 12-27-2009, 10:33 PM   #5
chipflyer
chipflyer's Avatar
No it was not a factory option in 1971 or 72. It was available from the dealer. No option code is listed in the 71 or 72 dealer data books that I have, but you could order it in 69 or 70. Maybe even 68, I can't remember for sure.
Jeff
Old 12-27-2009, 10:51 PM   #6
72 Super
72 Super's Avatar
Thats what I had thought, but wasn't sure. That sure is a nice complete set up.
Old 12-27-2009, 11:08 PM   #7
71blksuper4x4
SWB 4x4 Collector
Jeff, I will look at the ones I have, I don't think that one is the one I am looking for unless the one on your truck matches this one. I have the correct servo like yours now and am just missing the transducer mount. Trevor
TREVOR
Old 12-27-2009, 11:22 PM   #8
chipflyer
chipflyer's Avatar
I'm off tomorrow Trevor, I will compare it with the one on my truck. I moved a bunch of snow and found that in a box and didn't even think to compare them. Think I was a bit numb from the cold.
Old 12-28-2009, 12:05 PM   #9
jaros44sr
jaros44sr's Avatar
Cruise control
I am not familiar with pricing on this item, but would like to ask your opinion on the price. Does the unit look complete to you?
I am considering the purchase of the item, but would like your input...thanks for your time
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-28-2009, 12:35 PM   #10
71blksuper4x4
SWB 4x4 Collector
If Roger says it's complete, it's complete. Roger is a stand up car guy. Bought NOS parts from him in the past.
TREVOR
Old 12-28-2009, 12:41 PM   #11
71blksuper4x4
SWB 4x4 Collector
He does say that it is missing the vacuum tee. Trevor
TREVOR
Old 12-28-2009, 01:15 PM   #12
chipflyer
chipflyer's Avatar
Its complete minus the tee, which can easily be made from your existing tee but it also has the wrong switch. He does say that he has the correct under dash switch that he will include for another $95. It's a bit more than I would spend, but it is very nice and you don't see them listed in that condition very often. The 71-72 servo shown is an extremely hard part to find.
Jeff
Old 12-28-2009, 01:30 PM   #13
jaros44sr
jaros44sr's Avatar
Thanks Guys! Great input! I was looking for Rep. of the guy and you provided that. Correct switch at this point isn't worth an additional 100
I have two problems
I have a 1406 Edelbrock with Lokar throttle and kickdown cables....mounting bracket for cruise/vacuum cable may be an issue
Accel HEI, which is very large, not much space on the firewall for vacuum mount
Any input?
So, if I can get around these two problems I may go for it
SAFETY FIRST
AS usual, off topic
Jim
Old 12-28-2009, 01:51 PM   #14
71blksuper4x4
SWB 4x4 Collector
the vacuum does not mount on the firewall like the 68-70 cruise. It mounts on top of the inner fender on the D.S. The transducer mounts off to the side facing the motor on the inner fender. Jeff, I just picked up the correct servo 2 weeks ago on ebay for $8, but like I said, I am missing the transducer bracket like what Roger has. I looked at all of them I have, I have 2 (68-70), 1 (72), 1(73-80). I believe you have the 73-80 type in the pic, but I bet you have the correct one like Roger has on your truck. Trevor
TREVOR
Old 12-28-2009, 02:09 PM   #15
chipflyer
chipflyer's Avatar
Just looked Trevor, and its not like the one on my truck. I found another that I had but its completely different too. Sorry, I guess I'm not much help.
Good score on the servo, I used to watch Ebay like a hawk for the cruise parts, you have found some great deals up there!
Jeff
Old 12-28-2009, 02:10 PM   #16
jaros44sr
jaros44sr's Avatar
Originally Posted by 71blksuper4x4 View Post
the vacuum does not mount on the firewall like the 68-70 cruise. It mounts on top of the inner fender on the D.S. The transducer mounts off to the side facing the motor on the inner fender. Trevor
Thanks for the info, solves one of the problems. Do you have any pics or info. on how the cable mounts to the intake/carb?
SAFETY FIRST
AS usual, off topic
Jim
Old 12-28-2009, 02:43 PM   #17
71blksuper4x4
SWB 4x4 Collector
Jeff, what does the other look like? I could tell you pretty much from looking at it what style it is.
Jaros, Jeff has the instructions for installing these, it should give you an idea of how everything goes together. My truck is in pieces right now getting it's second rebirth. Trevor
TREVOR
Old 12-28-2009, 02:45 PM   #18
71blksuper4x4
SWB 4x4 Collector
Jaros, what year of truck/blazer are you putting this on? Trevor
TREVOR
Old 12-28-2009, 03:07 PM   #19
jaros44sr
jaros44sr's Avatar
Well, it was a '72 Jimmy, but I put a '68 Chevy front clip on it. GMC grille just had too much chrome on it for my liking!
Hooking it up to the carb is my only problem now, just doesn't seem like there are enough places to hook up the vacuum linkage. Maybe he'll help me out with pics
SAFETY FIRST
AS usual, off topic
Jim
Old 12-29-2009, 03:50 PM   #20
jaros44sr
jaros44sr's Avatar
Cruise control
Thanks for the link, talked to Roger today and it seems like I bought it!
Nice to have the help from the forum guys
SAFETY FIRST
AS usual, off topic
Jim
Old 12-29-2009, 04:27 PM   #21
teeitup
Just like to part out trucks!!
teeitup's Avatar
Roger knows his truck stuff, I think you'll be happy with it
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
