Old 12-27-2009, 05:45 PM   #1
b454rat
Amp to volt gauge
Saw this somewhere now I can't find it. I have a super nice big truck tach dash that has the fuel gauge in with the tach, and has an air gauge where the normal small fuel gauge will be. I want to put this in my 89 crew, but that has the volts not the amps. I'm hoping I can just rewire the amp gauge, but if not what do I need to do??
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-27-2009, 10:08 PM   #2
b454rat
Re: Amp to volt gauge
anyone?
Old 12-27-2009, 11:22 PM   #3
ray_mcavoy
Hi b454rat,
Seeing as how your truck is already wired for a voltmeter, I think it'd be easiest to swap a voltmeter into the tach cluster.
If I remember correctly, there are 3 square holes in the cluster housing behind the ammeter/voltmeter location. Two of them are used for the snap-in electrical contacts that connect the printed circuit to the gauge. The other is unused. And the position of the unused hole is different for ammeter vs. voltmeter. So swapping a voltmeter into your tach cluster would involve re-locating one of those snap-in contacts. And probably adding a little jumper wire since the printed circuit won't have a trace going to that formerly unused hole.
I'd also be a good idea to follow the printed circuit traces back from the ammeter/voltmeter location to the instrument cluster plug. Do that on both your existing cluster and the tach cluster just to make sure they both lead to the same locations on the cluster plug.
ray_mcavoy is offline   Reply With Quote
Old 12-27-2009, 11:53 PM   #4
b454rat
I have a couple of dashs here, got looking at them and traced the wires back. They both go to the same spots on the plug, just the location of the pins on the back of the gauge is different. I think all I need to do is make a small hole for the snap connection thing and install the volts gauge.
Old 12-28-2009, 02:00 AM   #5
SCOTI
SCOTI's Avatar
Just swap the amp & volt gauges. If the contacts are removed so it doesn't contact the printed circuit, the amp gauge is non-existant. The volt gauge only requires a ground & 12v supply from any power source under the dash.
My 74 had an amp gauge. I got a dash cluster from Jonboy that had a voltmeter (which is what I wanted). I removed the amp gauge & swapped the voltmeter in it's place (direct swap). Since my OE clock didn't funtion, I simply used the power wire to it for the 12v supply & ran a ground wire to the chassis. Works like a champ.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-28-2009, 03:52 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Is your speedo cable driven or an electronic one? I did this swap a couple years ago on my '90 burb with an electric speedo.
If it's a cable driven one, it'll be ALOT less involved than what I did.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-28-2009, 09:02 AM   #7
b454rat
It's cable, out of a 74 C70 IIRC. I was gonna put it on evilbay, but since my crew is gonna be a gasser and not a diesel, figured might as well use it. Get some silver overlays for it, swap the air for clock or something else, and use it.
After I got looking at it, didn't look like it would be a big deal, but would rather wait and see what the experts would say. ")
