Old 12-27-2009, 06:59 PM   #1
dbmx66
big problem! help!
so i got a new dif cover and bolts for my rear axle. im putting the new stuff on and the one bolt twists and breaks. its the bottom most bolt on the ring. i couldnt reach it with needle noses or anything else, no biggie, ill get an easy out. so i get the hole drilled in the bolt, start turning the easy out and it breaks in the in bolt. i cant turn the rest out with pliers or anything, so what on earth do i do now?!?
dbmx66 is offline   Reply With Quote
Old 12-27-2009, 07:08 PM   #2
2tons of fun
Re: big problem! help!
put a nut over it and weld the inside of the nut to the peice, let cool, twist out.
you can also try and get a left hand twist/reverse twist drill bit but with the easyout in there i wouldnt bother.
2tons of fun is offline   Reply With Quote
Old 12-27-2009, 08:10 PM   #3
dbmx66
how should i weld the nut? the piece of the bolt that broke is recessed into the housing. like i can touch it. so i dont know what to do.
Old 12-27-2009, 08:20 PM   #4
BREIT1
i wouldnt worry about it
1963 CHEVY C-20 292/4-speed-Hydraulic dump bed
1974 GMC C-25 454/400 Camper Special
1977 CHEVY K-10 350/350/203 shortbed
1979 GMC C-15 250/465 short bed, stepside
1980 CHEVY K-20 350/465/205
1980 CHEVY K-20 (Built)427/400/205
1981 GMC K-15 350/465/208(Retired)
1983 GMC K-35 454/465/205 winch truck
1985 CHEVY C-30 454(18,000 m.)/465/PTO
BREIT1 is offline   Reply With Quote
Old 12-27-2009, 08:45 PM   #5
1LowToy
RTV sealant works wonders. Not for show and tell in your case lol
1LowToy is offline   Reply With Quote
Old 12-27-2009, 09:06 PM   #6
Ceeten
Weld through the nut with a mig. It's really easy. I've done it dozens of times.
Ceeten is offline   Reply With Quote
Old 12-27-2009, 11:39 PM   #7
dbmx66
you think i'd be fin without that bolt?
Old 12-27-2009, 11:40 PM   #8
dbmx66
what do you mean?
Old 12-28-2009, 12:27 AM   #9
2tons of fun
nuts have a hole in the middle, put the wire throught the middle and pull the trigger.
Old 12-28-2009, 12:30 AM   #10
dbmx66
i know that. how will welding a nut to the dif help me get the broken piece of bolt out?
Old 12-28-2009, 01:22 AM   #11
2tons of fun
you not welding it to the diff!!!!!!, you weld it to the broken bolt !!!!!!!!
Old 12-28-2009, 02:49 AM   #12
bikes&bowties
bikes&bowties's Avatar
From the sounds of it the broken bolt is recessed into the diff case.... which makes welding the nut to it basically impossible.. But with my pondering it may be possible finding a nut with the outside diameter being smaller than the bolt and making a small spot weld on the inside of it... that may be ridiculous though
bikes&bowties is offline   Reply With Quote
Old 12-28-2009, 03:39 AM   #13
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Can you get a grip on the broken off extractor? If so get a a pair of vise grips on it, heat up the housing aorund the bolt to cause the metal to expand enough to allow you to unscrew the reaming portion of the bolt out.
OR....
Get a HELI-COIL SET that's the same size as the bolt holes are, drill the hole out with the supplied drill bit, tap it it out with the supplied thread tap and then insert the heli-coil.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-28-2009, 03:41 AM   #14
2tons of fun
it will work, try it. i do it all the time.
most break off a tiny bit under the surface.
Old 12-28-2009, 07:57 AM   #15
billnorman
I agree with the RTV suggestion. Enough of the stuff will probably seal over the missing bolt. As a S.W.A.G. you could probably drill and tap two 1/4 x 20 holes next to the missing bolt and use these to tighten the housing if it still leaked. The cover wouldn't look like it should, but I'm guessing it would work. Transfer drill the new holes through the cover so as not to misalign them. >The above is a S.W.A.G., just a Scientific Wild Assed Guess, I don't know if it would work.<
billnorman is offline   Reply With Quote
Old 12-28-2009, 08:42 AM   #16
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Little sillycone and you should be fine,Shaved a 14 bolt and cut one bolt hole completely out. No leaks and I'm fairly sure you don't run yours as hard as I have run mine.
powerdriver 1958 is offline   Reply With Quote
Old 12-28-2009, 09:40 AM   #17
68 TT
Still plays with trucks
68 TT's Avatar
They make a four pronged tap extractor for when you break off a tap in a bolt hole. It may work on the e-z-out too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-28-2009, 10:54 AM   #18
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
heli coil all tha way!!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 12-28-2009, 11:42 AM   #19
dbmx66
thats exactly what happened. its recessed a good couple o millimeters.
Old 12-28-2009, 11:43 AM   #20
dbmx66
OR....
i've tried vise grips theres not enough of the easy out sticking out to get a good grip on.
Old 12-28-2009, 11:51 AM   #21
billnorman
All this talk about drilling through an easy out sends chills down my spine. Most easy outs are tempered steel, kinda like a drill bit. They don't like being drilled on. Maybe I'm chicken, but I see melted drill bits in your future. Now if you had a fixture you could keep the bit from wandering, you might be successful but in my experiences freehand drilling a hardened material just caused the bit to wander off into the cast iron housing and further butcher the job. RTV likes you, give it a try.
Old 12-28-2009, 12:28 PM   #22
dbmx66
yea i got to vo tech for presicion machining so i know the differences between metals and tool steels so i wasnt even going to try to drill it.
i was thinking maybe since its the bottom bolt that i could drill from the other side, would that work?
Old 12-28-2009, 12:53 PM   #23
68 TT
68 TT's Avatar
Drilling from the other side is an option but you would have a tough time getting the hole in the right spot on the curved surface. I have seen some housings that were drilled part way through the back side so you may get lucky and have a guide point to work from.
Can you weld a nut to the e-z-out?
After you get it out use a left hand drill bit to drill out the rest of the broken bolt. Lots of times the piece will break free and thread out during the drilling process.
I fixed literally thousands of broken fasteners as a machinist in the air force. Probably averaged ten a night for 13 years.
Old 12-28-2009, 04:34 PM   #24
midnite
midnite's Avatar
iif you can do small tacks on the bolt/easyout untill the welds stick out enough to clamp visegrips on and heat the housing and go slow back and forth motion and it should come out.... BUT just tack the middle of the bolt take your time.. tack let it cool then repeat to build it up enough... dont weld it to the housing
midnite is offline   Reply With Quote
Old 12-28-2009, 04:56 PM   #25
tommys69/454
1969 short box
tommys69/454's Avatar
the easy out should come out if worked at with some finesse. then take a much smaller drill and drill all the way through the bolt. then re-drill the the easy out dia. to clean the hole. spray some pb -blaster or something similar in the hole. let stand. then with a buddy ( one bot as stronge as you) keep mild pressure on on the easy out while heating the housing. may-be a couple of taps to the housing. patients will pay off here the most.
tommy morehouse
tommys69/454 is offline   Reply With Quote
