Balancing
Hi,so I'm looking at buying a Longbox c10(64),and was wondering what I should do to try and add some weight to the rear for better handling.Heres what I got so far:
1. Moving the gas tank to the rear 2.Using fibre glass in the front 3. Moving the engine back So ya I would appreciate feedback and ideas.Thanks |
Re: Balancing
The trucks that I've had in the past were newer models. I have found that I like the ride a little better with about 200lbs in back. In my case I used hard tonneau covers that weigh a little over that. It lowered the back of the truck very slightly and rode smoother.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
Re: Balancing
Move the battery to the back
fuel tank back Softer rear springs
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Re: Balancing
you will need to put the dist next to your butt cheak to make any real differance.
diamond plate bed floor gas tank battery sparetire carrier heavy bumper....... |
Re: Balancing
Dude just put some weight in the bed.... could be free if your creative or have enough crap laying around.... Gas tank will do almost nothing being as stock location is in the middle of the truck. Relocating the battery gives you 50 or so pounds.... Moving the engine back.... Honestly without completely altering the design of the truck I think you would spend moeny and time and have little benefits.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Re: Balancing
movin the battery back to the rear is like movin the engine back 10 inches
65 gmc 930 292 4speed 700-18 duals 39k all original 65 chevy 10 long fleet parts truck 63 gmc 950 camperized bus 350 4spd 2spd axle 64 gmc 950 spare bus 53 gmc 1ton dual bus 79 gmc c20 short course offroad race truck 355 th400(www.wheel2wheel.ca) ![]() ![]() ![]() |
Re: Balancing
How hard would it be to say move the engine back a few inches?
Re: Balancing
what engine / trans combo are you using?
Re: Balancing
Re: Balancing
If your running a v8 you`re already in the rear most holes in the front crossmember/motor mounts, to go any further, you`ll have to cut and build new fire wall, move transmission mount , fab new motor mounts off of frame, shorten drive shaft, cut new hole in floor for shifter, longer radiator hoses, new fan shroud, and a host of things I haven`t even thought of....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: Balancing
Do you still have your spare tire under the bed? try adding that and see if it makes a noticeable difference.
A rear mounted Blazer style gas tank, when full, probably weighs double what the spare tire weighed. I notice the difference between empty and full in mine. |
Re: Balancing
I drove my '65 SWB for years in sub zero weather... frozen roads, etc... I kept ten 100 pound bags of cement in the bed, up next to the front panel and it handled find with street tires. I had to keep the rear air bags up to level the truck, but that is what it took to keep from sliding around.... (By spring they had cured!!)
You'd have to put the engine in the bed before it had any impact on weight distribution. Tank and battery would add some, but not likely enough to offset the effort to move 'em back there. |
#13 |
Re: Balancing
i plan to mount my spare under the bed... i got one of those winder upper brackets off a newer model pickup. othe rthan that i would say less stiff rear springs is the easiest remedy
#14 |
Re: Balancing
62GMC is right, MOVE or REMOVE your weight, don't ADD weight.
Besides, your safer with the fuel out of the cab, and the battery will live longer away from underhood heat. I've heard nothing but bad reports on fiberglass parts for our trucks..hoods mainly.
292 + TKO500 |
#15 |
Zero Albedo
Re: Balancing
Pour or affix lead to the inside of your rear bumper, it's compact, invisible and it will put the weight behind the rear axle.
A buddy of mine did it with his El Camino in the 80's in Flagstaff, Az to help with winter traction- he swore it worked.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#16 |
Re: Balancing
Add some weight to see what difference it makes. Back when I drove a 2 wheel drive positraction daily driver I built a wooden storage crate that sat behind the rear wheel inner fenders and the tail gate. Then I added sandbags for weight.
Using this method you can approximate how much weight helps. I used (3) 80 lb bags, made a world of difference. In my case I removed the entire deal during non-winter months. Hope this helps. Last edited by lakeroadster; 01-06-2010 at 08:57 AM. |
