Old 12-27-2009, 10:37 PM   #1
kev2809
low n' slo
kev2809's Avatar
What are you guys using to cut frames?
just wondering. i dont have a plasma, and dont plan on getting one. i was looking at a sawzall i found on craigslist for cheap. its a ryobi rj160v. i was wondering if it should work well. i dont have a shop so im not looking at going to spend a 100 bucks on a Milwaukee..this one is for 35 and i might be able to get it cheaper. im gonna use it to cut my floor out and later down the road if i need to cut my frame.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-27-2009, 10:45 PM   #2
67chevy2wd
67chevy2wd's Avatar
Re: What are you guys using to cut frames?
I would use an electric grinder with a cut off wheel. That is what I used to replace all the rust on my cab along with a die grinder.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 12-27-2009, 10:48 PM   #3
72GREENC10
72GREENC10's Avatar
i agree with 67, a electric grinder like a makita with a cutting wheel, just make sure to invest a little into one, you get what you pay for as i always say. and make sure to buy a couple of cutting wheels
72GREENC10 is offline   Reply With Quote
Old 12-27-2009, 10:49 PM   #4
kev2809
low n' slo
kev2809's Avatar
ive been using a cut off wheel and my grinder for the body, but the frame is waaaaaaay thicker lol. i need something different for this
-_--_--_ _________
Old 12-27-2009, 10:50 PM   #5
kev2809
low n' slo
kev2809's Avatar
so a cutoff wheel on my grinder is gonna cut it better and faster than a sawzall?
-_--_--_ _________
Old 12-27-2009, 10:51 PM   #6
orange71
Look on craigs list for used/new tools. Lots of good deals out there! Sawsall and 4.5" grinder will be your best friend
orange71 is offline   Reply With Quote
Old 12-27-2009, 10:57 PM   #7
72hotrodder
THE TOY STORE
72hotrodder's Avatar
torch!!!!!!!!!!!!!! best tool in my shop. a million uses
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know.
72hotrodder is offline   Reply With Quote
Old 12-27-2009, 10:57 PM   #8
kev2809
low n' slo
kev2809's Avatar
lol...a torch doesnt cut good lines though do they? this is something that it is getting cut then welded back together.
-_--_--_ _________
Old 12-27-2009, 11:26 PM   #9
72hotrodder
THE TOY STORE
just takes practice to get good strait lines. or you can clamp a piece of metal along were u wanna cut and use as a guide. plus all it takes is a quick pass with a grinder to clean up a little slag. alot quicker and economical than burning through disks and sawzall blades.
Old 12-27-2009, 11:47 PM   #10
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I have cut a lot of frame pieces with a milwaukee saw like what you are asking about and have had good results
ksbrktracer is offline   Reply With Quote
Old 12-27-2009, 11:57 PM   #11
scotts62
One day...
scotts62's Avatar
The only problem with a sawzall it its hard to get the lines perfect, but if your just hacking something off then it works great. A 4 1/2 grinder with a cutoff wheel blade works really good just dont let it bind up or the blade will come apart.
Scott
93 crew cab build
Project 62
Old 12-28-2009, 12:12 AM   #12
kev2809
low n' slo
kev2809's Avatar
well its for a z later if i try it. now its just to cut off my floor
-_--_--_ _________
Old 12-28-2009, 12:19 AM   #13
Wildstreak
"something witty here"
Wildstreak's Avatar
I would go with a grinder as well, I would think a sawzall would be brutal for cutting body panels. And a small cut wheel on the grinder will cut through that frame like a hot knife through butter.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 12-28-2009, 12:33 AM   #14
67chevy2wd
67chevy2wd's Avatar
If you already own a grinder then it would be cheaper to invest in a few cut off wheels. If you buy a sawz all then you will also need to buy some blades for it.
'71 GMC 3/4 ton 4x4
Old 12-28-2009, 12:49 AM   #15
kev2809
low n' slo
kev2809's Avatar
true. man that's odd. so what's the point of anyone using a sawzall over a grinder? I always thought the sawzall was the ideal tool for this...guess not.
-_--_--_ _________
Old 12-28-2009, 01:16 AM   #16
Wildstreak
Wildstreak's Avatar
dont get me wrong I use my sawzall all the time, for those tricky bolts that my grinder cant get to and other nameless jobs lol
57 chevy 4x4
68 burb 2wd:
Old 12-28-2009, 01:38 AM   #17
FnLow69
FnLow69's Avatar
same here... have had them come apart not fun.
FnLow69 is offline   Reply With Quote
Old 12-28-2009, 01:46 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
If your going to buy a Sawzall I suggest a battery powered unit. I have an 18v DeWalt that does a great job. It has tons of uses with the proper blade. I find it really handy for pruning trees.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-28-2009, 09:00 AM   #19
scotts62
One day...
scotts62's Avatar
Sawzalls are cool but if doing a Z i personally would use the grinder/cutoff wheel, its a cleaner and more accurate cut..
very true plus you can take it to a pull-a-part too
Scott
93 crew cab build
Project 62
Old 12-28-2009, 11:26 AM   #20
chevyrestoguy
chevyrestoguy's Avatar
I thought I was the only guy who did that. Those things work awesome as tree trimmers!
chevyrestoguy is offline   Reply With Quote
Old 12-28-2009, 12:17 PM   #21
463
463's Avatar
i use Zip cut cut off wheels with nice results.
Trueman
463 is offline   Reply With Quote
Old 12-28-2009, 12:44 PM   #22
kev2809
low n' slo
kev2809's Avatar
well, i guess i can get a sawzall another time...time to buy some cutoff wheels now. are they gonna be big enough to cut through a suburban floor too?
-_--_--_ _________
Old 12-28-2009, 01:29 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
You know you can put a tile blade in your circular saw don't you? That works great for cutting large areas like your floor. You will need a smaller saw for the tight spots.
Articles-
"Refining Sierra"
Old 12-28-2009, 01:31 PM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
I use a very aggressive blade to trim my palm trees. It's like giving a cat a bath if you use a hand saw or pruning loppers. My DeWalt cuts them like butter.
Articles-
"Refining Sierra"
Old 12-28-2009, 01:35 PM   #25
kev2809
low n' slo
kev2809's Avatar
"your" circular saw? i dont have one of those either lol. man oh man i need to start getting some more tools instead of buying parts lol
-_--_--_ _________
