Old 12-27-2009, 11:21 PM   #1
Raymond C. Pyle
1970 GMC engine swap
I am taking a 396 turbo 400 out of this truck and installing a 350 so my teenage son can drive it. Are the motor mount stands different? Does engine move forward or back etc? I am just looking for some advice on what I may encounter. This is an awsome forum.
Raymond C. Pyle is offline   Reply With Quote
Old 12-27-2009, 11:42 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 1970 GMC engine swap
I think you can just put it in place of the big block with out any issues.
But to answer your question, the stands are different.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-28-2009, 12:57 AM   #3
po_bird
po_bird's Avatar
Everything should drop right in. You might have to get the short style water pump and make sure to use the 454 flexplate.
po_bird is offline   Reply With Quote
Old 12-28-2009, 10:40 AM   #4
Raymond C. Pyle
any easy way to identify the stands? You mean use the flexplate from the 396? Also i may use a 283 I already have, its from a 1967 Elcamino would I use the same flex plate and if so is there a starter prblem?
Old 12-28-2009, 11:56 AM   #5
LONGHAIR
You CANNOT use a 454 flexplate on anything else. It is from an externally balanced engine, which would be out of balance, and vibrate something fierce.
Your 350 needs a "neutrally balanced" flexplate.
BTW, if the big block is the factory engine.....keep it. Not only because you may be tempted to put it back in later to get more power, it will definately increase the re-sale value to have it. (even if it is not installed)
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-28-2009, 12:00 PM   #6
kwmech
If you just pull the engine, the small block will bolt right in with the big block stands and mounts. Check your flexplate on the 350 and see if the torque convertor bolts line up on the convertor lugs
