Bed bolt removal
Any tips on the best way to get the bolts to stop spinning when you unloosen the nuts? Or, what to use to just simply remove the bolt and nut from the equation? Thanks!
One day.....
Re: Bed bolt removal
With a grinder cut a groove on the head of the bolt. To make it look like a slotted screw. Then with someones help and a flat head screwdriver, ask them to hold the "screw" you just made, while you get under the truck and loosen the nut. Hope this helps.
DZL1. |
Tack weld nuts on them easier to hold than the screwdriver or use the good old cuttin torch.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
Burnouts are therapeutic
drill the heads out ,don't even try to loosen them
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
Get your impact out (I can do it with my long handle ratchet) and TIGHTEN them, yes I said TIGHTEN them. They will easily break off. much easier and quicker than the other options and you were going to have to replace them anyway.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
i've always just ground the heads off wilh a cutoff wheel soas to not mess up the square mounting holes in the bed floor
Amen brother! If the bed wood is rotted and the bolt is loose use vice grips. The tighten until the bolt shank twists in two.
I tighted them down and used a wire brush on a air tool to remove most of the rust. Then Impact to take them off. I had to cut slots on a few bolts. Took the whole bed apart only broke 3 bolts......
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
Nothing to see here.....
![]() Join Date: Jun 2007
I drilled mine out from inside the bed, then whacked them out from the top. easy as pie.....
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
