Old 12-28-2009, 04:46 AM   #1
hoplias
electric window help
I am going to fix the elect windows in my 87 silverado and I wanted to get some input first on what it might be.
both the windows go up and down very slow and not constant .They did work about a 2 years ago befor I go the truck back .Any ideas and what best plan to go abouts it .
hoplias is offline   Reply With Quote
Old 12-28-2009, 07:48 AM   #2
billnorman
Re: electric window help
I cleaned and lubed the metal tracks and exposed gears of my manual window '85. Also sprayed the fabric tracks after I changed the window seals with silicone. They work like brand new. Before, they would hardly move without pushing and pulling them. Suggest you try the same, I was amazed of the difference. I also glued carpet to the inside of the doors to try to help the noise factor when they closed, but got minimal results. Good luck.
billnorman is offline   Reply With Quote
Old 12-28-2009, 09:46 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
^x2
The grease gets petrified and contaminated with dirt then it doesn't work very well. Tracks and in the motor housing.
You could also have the problem I had on my old truck. The rollers were seized up so even with new grease they just drug across the tracks. If your rollers are rusted up you might be able to free them up with some work but it is probably easier to find a donor truck and snag a better set. That is what I ended up doing after fighting with trying to free up the rusted ones on mine.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-28-2009, 10:41 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i made my 85 manual,from electric,simular issues,found cracked wires in the bend of the door jam,another friend had some probs made a seperate plug to test run them.found they worked better this way it confirmed wires not tracks he too made them manual
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-28-2009, 11:07 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
anytime ive had slow power windows or hard to crank manual windows lubing them helps alot
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
